Results 1 to 6 of 6
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Jun 01 2008
    Apopka, FL
    Re: So what happens if I toss some 100 octane into a stock motor?
    octane simply measures the fuels resistiance aganist knock.. you could use 100 in a car designed for 93 all the time if you wanted.. and could afford it, but there wouldn't be any difference from it being 100 octane.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    X2, what he said.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Apr 28 2008
    Houston, TX
    Oh ok... guess ill just get it for the formula car then!
    Registered Member Two Rings
    Nov 01 2004
    90 Celica All-Trac, 01 A4 1.8T
    Bothell, WA
    If anything the car just may run crappy and not get very good mileage. It's a common misbelief that running higher octane is better for a car or will yield more performance. Your best bet is to run what it's designed for. Same goes for a car that takes regular, not good to put premium in it.
    Roger
    90 Celica All-Trac
    01 B5 1.8TQ
    Jan 25 2006
    A4 2.0T
    MD
    Nothing good.
