Results 1 to 40 of 75
    Mar 03 2008
    05 s4 07 gli
    south florida
    oil change intervals
    how long do you guys go in between oil changes?I searched,found no good results!!thanks everyone.
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Re: oil change intervals
    10K, like factory service recommends
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Quote Originally Posted by s4dude View Post
    Depends. My school of thought is as follows.
    4k-5k intervals are my standard, however if the car has been doing a lot of highway cruising I'll change at 3,000. This is because (as the owner manual states) the car consumes a lot of oil on the highway and I frequently top off. This makes me worried about mixing old/new oils.
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Quote Originally Posted by NYCS4Avant View Post
    I would suggest the opposite - mixing old/new oils doesnt have any negative effects but driving mostly city where the oil doesnt have a chance to cover internals is where you need to change it sooner.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    I change my oil once a year, but that's irrelevant because my car sits all winter and isn't driven more than a couple of thousand miles during the driving season.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Every 5k
    Nov 27 2006
    07 RS4-E63 M6-07 A3 2.0T
    San Diego
    i do every 3k. Full Synthetic. What i cant understand is there is no oil in the world that can last 10k and still be healthy for the car. I believe that 5k is the max that one should go to change the oil on there cars especially if they are modded and running the motor at a higher level then stock. If anyone has seen an oil change at even 5k miles they will see it is pure black indicating that it is overdue. I recommend every 3k it costs me 38 bucks at a local guy i know in socal that does full synthetic oil changes with top end oil. I feel better and so does the car.
    Audi RS4 | Mugello Blue on Black | Premium Package | Valentine 1 | SOLD
    Audi A3 | Ibis White on Black | DSG | S-Line | Cold Weather | Open Sky | Audi Navigation | Technology Package | Premium Sound | APR Stage 2 | GHL Exhaust | KWV2 | Neuspeed Intake | APR Fuel Pump | Hotchkis Sways | AWE Vent Boost Gauge Soon | Blackout S-Line Grille | JL Audio Full Sound System | EuroJet FMIC Soon | Weight Reduction | SOLD
    Jan 24 2008
    West Coast
    Quote Originally Posted by AudiOso View Post
    Bingo. I'll be lucky to have put 5,000 on the car in one year. As it stands now, January 2008 - Present - less than 3,000 miles.
    Moderator
    Apr 11 2008
    Pasadena, CA
    Quote Originally Posted by SoCalRS4 View Post
    You have results to back the statement up?
    If Audi is going to CPO my car and warranty it for an additional 2 years outside of the standard warranty AND their service recommendation is every 10K miles with VW/Audi approved oils then I am going to hold them to that standard.
    Links of interest:
    http://blogs.edmunds.com/strategies/...too-often.html
    http://tedserbinski.com/2006/04/03/h...aybe_too_often
    It doesn't appear that the oil's color has anything to do with it needing to be changed: http://www.synthetic-oil-tech.com/d....tion_level.htm
    In my opinion, a $20 analysis is really the only definitive answer, http://www.blackstone-labs.com/index.html
    The Avant Garde
    Established Member Two Rings CasaS4's Avatar
    Dec 14 2006
    Atlanta, Ga
    While every situation is different, the folks at Blackstone labs might disagree with you. Several of my friends send their oil in for analysis and the Blackstone guys tell 'em to go longer between intervals. The actual color of the oil is not nearly as important as what chemicals and metals are in it.
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    Since synthetic oil doesn’t break down, but gets dirty from combustion, I change every 5-7K depends on how dirty the oil is, or every 6 months since I don’t drive a lot. In 6 months the oil has accumulated water from combustion and humidity and therefore should be changed.
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Dec 05 2006
    So. Cal.
    Every 3k for me. I know, it's waste of money. I hear that all the time. But wait till I go and sell it and see how many of your guys are going to want a car that had 3k oil change intervals.
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    $38 for a full synthetic oil change? That doesn't sound right. The cost of oil alone should be around $45 at the minimum (9 qts at $5/qt) What brand of oil are you using?
    Feb 15 2007
    Every 5k miles or 1 year... which ever one comes first (1 year for me!)
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2023 Mini Cooper SE - White Silver Metallic
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by FastB7S4 View Post
    I think, or I hope that he is referring tothe labor only.
    Mar 01 2008
    yeah but he says the guy does full synthetic oil changes with top end oil so to me that implies that the cost is inclusive of oil and labor.
    Dec 05 2006
    So. Cal.
    I saw that too but was giving him the benefit of doubt. however, he might be getting dino oil and not even know it, as he didn't seem to know the brand of oil going into his car.
    Registered Member Two Rings Fleet Admiral's Avatar
    Mar 12 2009
    A6 2.7 | ecodes | CH air comp|
    MI | umich.edu
    Try more like $8/qt for REAL FULL synthetic, ie: Motul, ELF, Lubro Molly, Pentosynth.
    None of this US store bought isht like mobil. From what I heard, 0w40 is no longer group IV, meaning it's crap. And Porsche no longer endorses it. Could be just rumor, but I'm playing it safe and sticking to the euro blend 5w40 and go 8,000mi intervals.
    Oh, and if we burned alcohol for fuel, the oil would stay newer looking, longer.
    You can't lose choosing me doll face. Every lotto ticket I scratch off is a winner, cuz I'M a winner
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    3 months or 3k miles. It's a waste of money, but it's my car. ( I do it on 3 of the 4 cars I own. I haven't changed the oil in the GTO in a year, but I think I've only put 50 miles on it since then.)
    Veteran Member Three Rings abe's Avatar
    Feb 22 2009
    2008 S4 Avant, 2015 Q7 TDI, 2017 Q5, 2013 F-450, 2015 Ford Edge SEL
    Although I am a new guy and haven't changed the oil yet, I like the 5K interval myself. That way, when the ODO hits a 5 or a 10 (5K, 10K, 15K, 20K, etc.) you do oil and rotate tires. Just makes it simple.
    My car with 2.2K miles on it is telling me to change the oil at 4900 miles. Right on target, I suppose.
    I am going to send in the oil to blackstone just before the 2nd oil change at 10K miles, just to see.
    Onwards,
    -abe
    '08 B7 Ibis White Avant
    Registered Member Two Rings Midniteoyl's Avatar
    Mar 21 2009
    Indiana
    For what it's worth, I heard that Mobil1 is going to start using a group IV base stock again.
    I can still find 5w-40 in gal jugs at Walmart and bought several.
    5-7500k miles is where I change at, btw.
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    5k nothing more. I know they say they can go 10, but its cheap insurance. I sent my recent oil change to blackstone, everything was fine, and they said push it to 6500...But that only works out to less than 1 more a year. Even at 3k it only works out to 1 extra oil change. I can see it happening more often on a car with more stressed oil, and a smalled crankcase, Like the really worked 1.8s... mine used to only take 3.8 quarts. But in our cars, with 10 quarts of oil, even the 5k is overkill. But play it safe, go 5.
    Veteran Member Three Rings charliemike's Avatar
    Jul 24 2008
    Virginia
    I don't know whether to laugh or cry at that. I put 13k on my car in the last 9 months and I work at home
    I need another car to use as a beater or I'm going to have 100k on my S4 before I know what hit me.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    omg dude do you not know anything about german cars. Ok for starters 3k is way to soon. My oil is still fresh looking. And being black doesnt mean its bad. It all depends on the additive package in it. And If your paying 38 bucks for an oil change somethings fishy there. Unless you get a discount on mobil one. And yes you can go longer than normal oil changes simply because all german cars hold more oil than a tipical engine can hold. usualy a tipical v-8 can hold around 5-6 qts ours holds 10 qts count them 10 and a normal v8 can go 3-5K hence audi says 10k miles but figure 7-10 but i would change it at 5-6 myself. If you have more oil in the resivior the oil doesnt get broken down as fast as normally does with less oil. hence you can go farther on an oil change than normal.
    For the record unless you track the car or drive the wheels off 3K is way to soon you are wasting your money. I did 5K on my b5 s4 and the engine was clean as can be and i had it for 40K miles. And i did valve covers before i sold it and it was spotless in there.
    But hes right if you do more city miles thats gonna eat up your oil more than hwy. hwy miles are easy miles. Stop and go is killer on engines.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    5K
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Veteran Member Three Rings Veereihen6's Avatar
    Mar 06 2009
    Long Island, NY
    Do you guys take it to the dealership, a local mech, or DIY for oil & filter changes? (I'm assuming no one skips filter changes right??)
    2004 B6 S4 Avant 6MT Moro Blue - mostly stock for now
    1998 VW GTi-VR6 - mmmmm....listen to that VR6 growl! -sold-
    Jan 14 2009
    Audi's
    I usually change mine every 3k even if its a waste of money. I like the reassurance that my car has fresh oil in it.
    Mar 01 2004
    Northern NJ
    Quote Originally Posted by chaos2984 View Post
    Its not only German cars, most cars now take 6 quarts minimum, due to the EPA requiring longer intervals to reduce waste and hazardous oil. Thats why all of a sudden everyone can go at least 10k. I thought it was odd how they used to want you in every 3-5k for oil changes, but once the free maintenance came out, 5k on dino oil is ok...yea right. All BMWs took 6 quarts min since at least 2000. The Benzs have taken at least 6 for a long time. At least the bigger ones have been (not that c230 POS)
    Mar 21 2009
    Indiana
    Well, the '3000 miles' thing never came from the OEM' or the dealers. That came from all the 'Jiffy Lubes' and look-a-likes. The only time I have seen 3000 miles in a manual was for sever duty... taxi, cop, towing, etc.
    Oh, and more oil isnt always better...
    Dec 05 2006
    So. Cal.
    Topping off is your problem and one of the causes of your car burning more oil. Stop filling at the middle of the dipstick.
    On another note, the problem with running your oil for an extended period of time is that you lower the flashpoint of the oil (fuel getting mixed with the oil). That mixture ends up vaporizing in the crankcase, leaving through the PCV valve and reentering into your intake manifold where it burns and solidifies on your valves and other parts.
    Now for those without FSI, it's not as bad as the fuel helps keep the valves clean. However, thos of us that have FSI engines are F'ed as there is nothing to help keep the valves clean. This is one reason that I change my oil at 3k. Getting the fuel out of the mixture is just as important.
    Here is a shot of an RS4 motor with 19k on it.
    Established Member Two Rings eweu's Avatar
    Aug 25 2008
    Silicon Valley, CA
    It's cheaper to send in some oil for analysis than to change your oil too often. You can't tell if oil needs to be changed by looking at it or by knowing how long it's been in there. It doesn't take long to establish the proper interval based on the analysis. Another benefit is that you can see evidence of engine wear long before it becomes a problem. Why play games and "guess" when your oil needs to be changed?
    Oct 11 2007
    Suburbia
    Quote Originally Posted by Fleet Admiral View Post
    Motul is garbage from what Ive read, and the oil analysis's Ive seen. I stick to Lubro Moly for the RS. I think I may try Pentosin though, heard decent stuff about it.
    Oct 11 2007
    Suburbia
    Good advise Ed, but what do you mean by filling at the middle of the dipstick? thanks.
    Dec 05 2006
    So. Cal.
    Don't know the reasoning behind it but it seems to do the trick for me. Others have heard this as well.
    http://forums.quattroworld.com/rs4b7/msgs/651.phtml
    Mar 12 2009
    MI | umich.edu
    Quote Originally Posted by charliemike View Post
    I put 38k on my brand new passat in 8 months, always used 0w40 from 2nd oil change, back when I assume it was group IV, and did 5k intervals.
    I just believe the adatives in the euro/full synth blends is the reason for longer intervals, and the dealers crying foul of paying for full synth every 5k for euro cars. Not that the dealers used full synth to begin with, and cheated their customers, hence maybe part of the reason for the 1.8T sludge issue.
    When the manual says 5w40, I use it. 10w30 is a temp substitute only, regardless if one drives 140mph to work each day or not. I don't know if Audi or any other maker even knows the difference in blend quality, but if I recall, the approved list of oils is short for the US because they know the euro blends are hard to come by.
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    I wouldn't recommend anyone use 0w-40 in their B6 or B7 S4 after what I just went through.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    I've always done middle of the dipstick thing. I know first time I changed the oil on the S4 I mistakenly went a little over because I didn't check it correctly so on the few runs I made afterward I could smell the oil burning. Pulled some of it to make sure it sits in the middle and everything was back to normal. Now, 3K+ miles later there was no burning issues nor have I had to top-off.
    Dec 05 2006
    So. Cal.
    Another believer^^^ . That's good to know. 1/2 way FTW!
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    7500 here. When my Benz was still under warranty the dealership did the oil changes for free, but would only do then ever 10K using Mobil 1.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    May 30 2007
    MA
    Quote Originally Posted by serumk View Post
    huh? Elaboration?
    2014 R8 V10 - Gated
