on the info provided...
The code is: 17956 - Boost Pressure Regulation Valve (N75): Open Circuit P1548-35-10---Intermittent
I replaced the N75 about 13 months ago.
There is NO MIL, but the car is in soft limp (boosts to and holds 5 PSI). Right when I start the car (first few minutes of driving) the car will boost higher than 5 PSI (which I don't because not warmed up).
Also I noticed that during the day when it is hot it will always stay at 5 PSI, at night when it is cooler it will sometimes cooperate with my request (acceleration) and boost high (spike ~ 18 PSI) if I go WOT, but if I let off the throttle at ALL it will go back down to 5psi and hold regardless of me going back to WOT. Then if I change gears and go WOT again it will again boost high, but decrease and hold at 5psi if I let off the accelerator at all.
With the code already pulled I am quite confident and hoping that replacing the N75 will solve my issue.
With these symptoms are there any other things I should consider? I.e. wiring, but would that create intermittent signal, and the off/on boost based on throttle/temp? Or could wastegate actuator be issue, or would that throw different code?
I just want to check before I go spend another $100 on an N75.
Also "slow response from sensor 1 O2 sensor" code, which I do not believe has any correlation.
Update: Checked wiring and tubing from N75 and everything looks and feels good'n'tight.
