Results 1 to 10 of 10
    Senior Member Two Rings vince954's Avatar
    Aug 21 2008
    07 Audi A3 2.0t
    fort lauderdale, FL.
    07 A3 H&R sport cup, Rims and tires
    New guy here, I recently got a 2007 A3 with an H&R sport cup kit installed, I wanted to get a nice set of rims and tires for it but when I got 18in rims by 8.5in and general exclaims 225-40-18s I found that the rears rub the innner fender when I hit bumps, basically they rub the screw that holds the rear bumper to the rear fender.
    My guess is that I have to go with 8 in or 7.5 in wide rims, does anyone have recomendations or can confirm what fits, I also need to get the tire size I should be using.
    Registered Member Two Rings kwanja_a3's Avatar
    Mar 28 2007
    2007 Audi A3 2.0T S-Line
    Toronto, Canada
    Re: 07 A3 H&R sport cup, Rims and tires
    First of all, do you know what the offset is on the current 18x8.5" wheels that you have? Just trying to see if there's a way you can get those set of wheels to fit instead of buying new ones.
    That screw that it is rubbing against should be able to be removed and your bumper should still be secured, if you want to try that.
    2007 Audi A3 2.0T S-Line 6MT
    http://mydubspace.com/kwanja3
    Veteran Member Four Rings littlewhite's Avatar
    PNW Rainy States
    What offset? Yea the screw can be removed and if it still rubs it is ok b/c the back the material is like carpet so after some rubbing it'll be gone and can hear it
    Littlewhite
    Aug 21 2008
    07 Audi A3 2.0t
    the ones I got have a 45mm offset, I am told that to fit an 8.5in wide wheel I need a 50mm offset, is this true?
    I would rather not remove the mounting screw if possible and I would also like to avoid damage to the innner fender liner.
    Oct 30 2006
    2011 GT3 RS, 2011 C63AMG, 2012 E63 Wagon, 2010 ML550, 2006 A3 commuter
    ca
    if you wanted no rubbing you should have got 17x7.5 with 225/45/17 et 56
    Senior Member Two Rings UberA3's Avatar
    Jul 28 2007
    Las Vegas
    I am on 225/35/19 on 19" 8.5 et 45 and don't rub. I am lowered 2" on coilovers.
    2020 SQ5 Quantum Grey - Sport Package - Black Optics - Cete Controller - 034 ECU/TCU flash - AWE Exhaust, Intake, Intercooler
    2007 Misano Red A3 - DSG 2.0T - K04 - S3 body kit
    Mar 28 2007
    Toronto, Canada
    Quote Originally Posted by tpliquid View Post
    LOL, be nice tp
    vince954, yes that is basically true, if you got ET50 instead of ET45 on your 8.5" width wheels, you should be rub-free.
    I am on 19x8" ET 44 and that basically sticks out the exact same as 8.5" width wheels with ET50. So your car is pushing the wheels out 5mm more than my car, which can make a difference depending on how aggressively you drive in corners and how low your car is to the ground.
    If you want to keep the wheels, you could try to stretch 215 width tires instead of your 225. You will clearly see stretching, but it should be safe to run 215 tires on 8.5" wide wheels.
    Or get new wheels in a skinner width (e.g. 8" instead of 8.5") or with a higher offset than ET45, like you mentioned.
    Oct 30 2006
    ca
    i'll just not respond to these threads anymore caus i just get mad at people who cant handle minor rubbing for few miles.
    edit:
    take out the screw, it wont do anything. bumper not gonna fall off.
    if you really want no rubbing you should go 18x8 ET50 and find tires with least sidewall protection. this will give you extra room between fender and tire.
    Senior Member Two Rings KayC's Avatar
    Jul 03 2007
    Vancouver BC, Canada
    hey im running the exact setup , H&R sport cupkit with 18 x 8.5 et 45 and i took out the rear scews and it rubbed for about 100 miles or so then it stopped
    Oct 30 2006
    ca
    Quote Originally Posted by KayC View Post
    DOT
