Results 1 to 10 of 10
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    What spring for 007 with BT?
    The final parts for my GT2871r elim kit should be here any day now and I was cleaning up my room and found the extra springs and shims for my Forge 007. What I found was the Blue spring and Green spring and two spacers. I know the spaces are supposed to make the initial boost spike more solid for the sack of smoothness, but what are the weights of the different springs and which would you guys recommend with my 71r elim? How many spacers? Thanks.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: What spring for 007 with BT?
    Quote Originally Posted by Killerteve View Post
    I was using the blue spring with my GTRS but many people recommend using the yellow spring with 1 shim.
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Hmm I've been using the yellow one all along. At the time I installed it I for some reason decided to go with yellow and was REVO 2 at the time. Is the yellow stiffer than the blue?
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Green-5-15 PSI
    Yellow-15-23 PSI
    Blue-23-30 PSI
    Red-30 + PSI
    http://www.forgemotorsport.com/conte...roduct=FMDVTUN
    hpoe it helps
    Feb 17 2005
    Sarasota, FL
    I ran blue as well when I had a DV, yellow with a single shim should work too
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Not to confuse anyone, but I run the green spring and it works just fine.
    -Doug
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I run yellow, no shim...most of the time when the DV is in use, you are not at full boost but rather daily driving.
    The key is allowing the pressure to vent when it is needed.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I was studying my DV lay-out the other day trying to figure out if I need something stiffer than a green spring.
    Mine is situated so the TIP side is against the piston. The boost side is against the backside of the piston working in conjunction with the spring to keep things closed. I think that is how I'm able to get away with the lightest stiffness spring.
    I am so used to how my car is that I forget how it was situated from the factory.
    -Doug
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    I ran blue for a while. I now run yellow, no shim.
    I run in reverse so I don't know if that changes anything.
    My 2004.5 APR Stage 3+ is SOLD
    Established Member Two Rings michpan's Avatar
    Mar 15 2007
    Athens, Greece
    Quote Originally Posted by FourRings80 View Post
    Yellow-15-23 PSI
    This probably covers everything. The blue one would be too abrupt..
    Michael
    - Audi A4 1.8T B7 FWD+GT2x+carbonio
    + milltek exhaust+neuspeed xtreme tip
    + APR fmic+hofele bumper+ bilstein/h&r
    + votex rear spoiler/diffuser+DTM skirts
    + RS4 18' wheels+RS4 pedals+s4 mirrors
