which S4 rear calipers do I need to look for for my 97 A4 Quattro? and which rotors do I use with this upgrade?
is there anything else I need for this to bolt on and use?
My rear brakes are shot. I'm grinding metal to metal, and I have to buy new rotors and pads, so why not upgrade while I am at it, right! I need some help on this guys, so any replies will be greatly appreciated.
as for the fronts, I have the S4 aluinum uprights, but nothing else.
as I understand this, I need to get new hubs/flanges, which I still dont understand what to get here... I look up part and the bearings look just like mine (which is WRONG! A4 bearings are plain-jane press in bearings, while the S4 takes a different type all the "stock photos" used in ads is not helping at all.) once i get new bearings/hubs/flanges... I understand I will need B5 a4 2.8L manual FWD axles to fit the S4 upright hubs and also bolt to my transmission (01a)
Now I hope to have a 6spd to swap in next time my clutch goes out. (or when I destroy the 5spd) I made 517awhp yesterday and that's still without nitrous. New cams should be in, a VVT tensioner, tool steel wrist pins and I am ready to spray stage 1 and stage 2 (technically about a 140 hp shot of nitrous on top of over 500hp I dont think the 5spd will take it. any wagers?
SOOO, suppose I setup front brakes on the S4 uprights would I then use S4 axles if changing to a 6sd?
also, is there a part number for the bushing used in the lower control arm bore for these aluminum uprights? I have a CNC file for making them, but it's pretty expensive. I'd like to see if there's a replacement part available for less?
thanks for any help
