Results 1 to 11 of 11
    Established Member Two Rings brownstud08's Avatar
    Aug 23 2008
    Kansas City, MO
    Custom exhaust question
    i dont have the budget for an entire catback system so i thought of doing my own custom setup for the exhaust. I had two ideas and i would like to get some feedback on each toher.
    idea 1:
    replace piping from where the pipe splits into two to a 2.5 inch pipe and put 2 magnaflow 14851 mufflers.
    idea 2:
    take off resonator and remove all piping after resonator along with both mufflers. add one magnaflow 2.5inch in with duel 3 inch out mufler and run a 3 inch pipe all the way to the end of the exhaust.
    Does anyone have setup that resembles any of these ideas? Suggestions? I dont want rasp in the exhaust, im looking for a deep tone. Any help is appreciated.
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: Custom exhaust question
    Save up.. You'll hear these eventually so I thought I'd just get them out of the way for you:
    "Go big or go home"
    "Buy nice or buy twice"
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    cut it before the resonator. pipe back to a magnaflow resonator, then to two more magnaflows. unles you want the single exh outlet look, then use 1 magnaflow res to 1 magnaflow muffler.
    - Benny
    May 21 2007
    Florida
    leave the cat and downpipe, from the downpipe back do 2.5inch piping split into dual 2.25inch piping with some magnaflow muffers on the end. if you want it quiet, throw some resonators on after the split. i baught all my mufflers and resonators on ebay through performance curve. i never had a problem that wasnt my own fault (ordered the wrong resonators) and shipping was always fast. one muffler was missing a weld on the seam but that litterally took 15 seconds for the exhaust shop(my friend) to fix.
    ordering everything yourself and using resonators ide say youre looking at about $500ish give or take $100 depending on the shop. on my car, i had this set up with resonators and i could barely hear it. i put on my TP and thats what braught out the sound. ide recommend no resonators in your case.
    heres my current setup with tp and 2 resonators(skip the the end with the revving clip, the cruising part is too windy):
    http://www.youtube.com/watch?v=SA6EUUiAf3s
    here is my old car, same deal but used 3inch pipes with glass packs not resonators(not what i askd for but oh well):
    http://www.youtube.com/watch?v=2MvEilhCb1k
    2018 Navarro Blue Q5
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    I have your #2 scenario on my car. Resonator is still intact and 2.5 piping from the split back to two 14851's. I love it. I think it gives the car just enough sound to make you, the driver, enjoy it...but it doesnt attract alot of attention. Looks real good, too.
    When I go GTRS, I'll obviously have to complete the exhaust.
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Dec 06 2007
    what u could do is shop around for a custom deal my dp back exhaust with 1 resonator and 2 14851s with piping parts and labor cost me 400 bucks
    -Kirk
    BetaAlphaTau Member #58
    Aug 23 2008
    Kansas City, MO
    Quote Originally Posted by demea View Post
    do you have a sound clip of the exhaust? id like to hear how it sounds.
    Jun 12 2008
    Warminster, PA
    Quote Originally Posted by brownstud08 View Post
    I dont. Not really into sound clips, but if I get an opportunity...I'll make a quick video of it idling/revveing.
    What are looking for? Loud, quiet or in between?
    Aug 23 2008
    Kansas City, MO
    in between. i drive 60 miles a day in it so i dont want to go deaf but id also want it to be ab it more aggresive sounding than stock
    Aug 23 2008
    Kansas City, MO
    [QUOTE=doublezero30;2881061]leave the cat and downpipe, from the downpipe back do 2.5inch piping split into dual 2.25inch piping with some magnaflow muffers on the end. if you want it quiet, throw some resonators on after the split. i baught all my mufflers and resonators on ebay through performance curve. i never had a problem that wasnt my own fault (ordered the wrong resonators) and shipping was always fast. one muffler was missing a weld on the seam but that litterally took 15 seconds for the exhaust shop(my friend) to fix.
    that is without the stock resonator right and what is the stock piping of the car?
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    Quote Originally Posted by doublezero30 View Post
    what mufflers/resonators are you running? part numbers. . ? sounds good so you have tp stock down pipe 2 resonators and thats it?
