youre fine. your coolant temp sensor is shot. easy fix if you have small hands (unlike me) and a $25 part from the dealer. i think a4mods has a writeup. just know the retainer clip goes on at an angle. thats what F-ed me up for about 20 minutes.
edit: here you go -->
http://www.a4mods.com/#index.php?pag...ECTsensor.html
read that completely. it is importent to do it with the engine COLD. and make sure you take the coolant resevoir cap off to relieve the pressure in the system, then put it back on before you take the sensor out. that way youll have no coolant overflow.
also, the sensor is hard to find at first. i thought it pointed out of the back of the engine at first, but i was wrong. it points straight up.
