Results 1 to 37 of 37
    Dec 28 2007
    2004 B6S4 6MT Nogaro
    Hoboken, NJ
    Windows up/down with key fob?
    Hi all,
    I've heard it's possible to program an Audi key FOB to open/close the windows and sunroof by holding unlock/lock, respectively. Is this possible on a B6S4? If so, can it be done by hand or do you need a VAGCOM scanner thing? And if you need a VAGCOM, does anyone have one in the Hoboken, NJ area? ;)
    TIA!
    Cheers,
    -Kurt
    2004 B6S4 4.2L Sedan (built 03/04, bought 09/07) | 6MT | Nogaro Blue w/ Black Leather w/ Blue Alcantara | CF Trim | 20% 3M Tint | AWE Non-Res Catback | 18" BBS RX | SportContact 2 (summer) | Blizzak LM25s (winter)
    2000 C5A6 4.2L Sedan (bought 07/05, retired 09/07) | Tiptronic | Ming Blue w/ Tan Leather | Wood Trim | Goodyear Eagle F1 GS-D3 (summer) | Blizzak LM22s (winter)
    Established Member Two Rings SOASOAS's Avatar
    May 31 2004
    Phoenix AZ
    Can be done with a VAG-COM...
    Windows open and close but the sunroof only closes on mine.
    Dec 28 2007
    Hoboken, NJ
    Re: Windows up/down with key fob?
    How'd you get it to do that?
    Cheers,
    -Kurt
    Jan 24 2008
    West Coast
    Mine too SOASOAS...
    ...and yes, you'll need Vag-Com.
    Moderator
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    Anyone else find it doesn't really work that well? I have to hold unlock about 3 times to get the windows down, and usually at least twice to get them up.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Quote Originally Posted by b spot View Post
    if you're initially locking your car, then you have to press it again to get the windows up, and if you're unlocking your car for the first time, then u have to press it again to get the windows to go down. Works like a charm for me.
    and yes, VAGcom will be needed. I also did the fog light mod via VAGcom (no wire splicing needed!), and unlocking all doors at the same time.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    I had my Audi dealer do it for me. I said it stupid that the car could do this but its just not programed, So they went ahead and did it for me.
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Registered Member Two Rings hackers4's Avatar
    Jun 12 2007
    Miami, Fl
    I've never had any problems with having to press buttons 2 and 3 times. You will need a vag-com to program the car. Unless your dealer is cool, they will charge you to do it. It only closes sunroof, won't open it.
    2005 Audi S4
    MTM Fullback Exhaust
    ASR Engineering Test Pipes
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stasis Center Differential
    Stratmosphere SS
    BBS RS-GTs
    Veteran Member Four Rings V8S4Fun's Avatar
    Jul 22 2008
    05 S4, 95 Jetta
    Taneytown, MD
    Quote Originally Posted by earhythmic View Post
    Do you know these codes still?
    [email protected]
    2005 Silver S4
    RAI Supercharged
    Unitronic Tuned
    JHM L/W Crank Pulley
    Custom 2.5" catless DPs w/Milltek Non-Res
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    I had my dealer do it for me as well as turn off the annoying seatbelt chime.
    Jan 24 2008
    West Coast
    ^ Yeah, that! Seatbelt chime - ftl.
    I occasionally will have to press the button more than once - but it's usually just a distance thing.
    Moderator
    Registered Member Two Rings coldfusion9xx's Avatar
    Sep 11 2008
    05 Audi S4, 07 Kawi ZX10R, 05 Fusion 900
    Lowell
    Oh man I need that seatbelt chime off ASAP!!!
    It constantly stays on in my car if the key is in the ignition in the on or started position, unless I have my seatbelt on...only after driving without a seatbelt for about 10 minutes will it shut off...even if I am parked it is on! Ugh
    How do I fix that? And how would one know if they have the VAG-com?
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    On the same lines of VAG-Com mods...
    ROTW FTW (no running ambers and fogs enabled w/HiBeams).
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Mar 01 2008
    Quote Originally Posted by coldfusion9xx View Post
    VAG-com is a software program in a laptop that you hook up to your car to re-program things like windows, seatbelt chime, etc. The dealer has another tool (can't remember what it's called) like VAG-com that they use. The dealer or someone who has a VAG-com can re-program your car to turn off the chime.
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Here's the deal, this stuff will cost you about $20 max. Go on flea-bay and get yourself a vag-com cable for about $15.
    Follow this tutorial: http://www.audizine.com/forum/showthread.php?t=158766
    The Ross-Tech software here: http://www.ross-tech.com/vag-com/download/archives.html
    You do not need to pay for the full version to clear codes or make the mods we are talking about here. You do need to pay if you want to see things like pending error codes (ones that haven't caused the CEL to come on yet) and data logging ability.
    Done. Now you can see your own CEL codes etc instead of paying the dealer, enjoy.
    One more edit, I think this works on both B6/B7s. I should warn though that the upcoming models will probably use the CAN interface (A3s and A8s already do) Those cables are different but can be had for $30.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Senior Member Two Rings mystro's Avatar
    Apr 29 2005
    Woolrich Pa.
    Doesn't it turn off the "bump safety" when using the one touch up feature for rolling up your windows. I did the key fob window feature back in 2001 in my B5 S4 and the bump safety was disengaged after it was programed. It was too dangerous so I had the key-fob code changed back.
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by ChronicTeutonic View Post
    yea you dont need the registered version
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    what's 'BUMP SAFETY?'
    Quote Originally Posted by mystro View Post
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Quote Originally Posted by sakimano View Post
    Apr 11 2008
    Pasadena, CA
    Quote Originally Posted by ngng View Post
    Dare I say it? That is cute.
    The Avant Garde
    Jan 24 2008
    West Coast
    HILARIOUS!
    Moderator
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    TX
    Quote Originally Posted by kloover View Post
    Hi all,
    TIA!
    You know, this is one mod that I won't do on my S4... I did this to my 99 A4, to get the windows to roll up you need to hold down the button on the key fob for a few seconds. While you're holding down the button the pump that controls the power door locks is running constantly which is a big no-no, on the B5 it was notorious for failure. My power door lock pump failed when I was rolling my windows up, I'm sure it would have died anyway but I'm also sure rolling up/down the windows with the remote hastened the failure. Just an FYI, the friggin pumps are expensive.
    Mar 15 2008
    TX
    If Sparkey above stuck his head out the window while the driver was rolling it up the bump safety would ensure that Sparkey wasn't decapitated. Kinda like the safety on a garage door opener.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    dont scratch my roof, lol!
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Apr 29 2005
    Woolrich Pa.
    "Bump Safety" The real answer is when the window is being powered up and there is a obstruction in the way like a hand or dog, the window stops and goes back down.
    Jun 02 2008
    ahh gotcha.
    why would it be disengaged just by that auto-up feature being engaged? strange combo.
    do you mean it's not effective (bump safety) when using the remote, but is still normally effective using the window controls?
    Jun 02 2008
    hmm...wonder who the pack leader is
    Mar 15 2008
    TX
    My answer was just as "real" as yours, sorry if it confused you.
    Apr 29 2005
    Woolrich Pa.
    The bump safety did not work at all when I had it programed for the remote window up feature. If I used the one touch up feature with the window switch, the window would not stop if there was a obstruction. This was with my B5 S4.
    Apr 11 2008
    Pasadena, CA
    Bump safety works fine with the remote and switches. I just tested it on my B6.
    The Avant Garde
    Feb 12 2017
    Utah
    Quote Originally Posted by martini View Post
    sorry for bringing this back to life..
    so on channel 62 my will only take up to 31 which it does not include all the sunroof but i am ok with out it
    the coding took just fine.
    my only problem is that i can wind the windows down just fine with the remote but i cannot make them go back up no matter how long i hold the button... any clues as to what i am missing ???
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Quote Originally Posted by oscar801 View Post
    I sometimes have this problem too. I've found it might take 2-3 tries before it responds. I usually have to momentarily press lock to set the alarm, wait a second, then press and hold the button again and the windows will go up. I sometimes have to press and hold a second time to make them go up. Same to roll them down sometimes too. (press to unlock, wait a second then press and hold to roll down)
    JHM Tune ~ JHM Intake Manifold ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ JHM 40/60 Rear Diff ~ JHM LSD Rear Diff ~ KW V3 Coilovers ~ Porsche 18Z calipers ~ BBS CH
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 04 2014
    2009 Gray A3
    California
    When it works, the windows closing when holding the door lock button will also close your electric sunroof
    Sent from my SM-G935F using Tapatalk
    Feb 12 2017
    Utah
    Quote Originally Posted by mad70sx View Post
    i am gonna keep trying hopefully i figure out how the car is willing to respond. Because i have no problem at all make them go down is just the going up the it struggles with.
    i wonder if it has something to do with me no been able to adapt channel #62 to the value of 95, whats weird is that when i put 95 on it an test it the computer brings it down to 31 by itself for some reason so i am no sure where the problem really is..
    maybe is my key i am looking into getting a new key as well soon sense my second key got lost at the lake this past summer so will see what happens.
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Quote Originally Posted by SOASOAS View Post
    only way that works.
    Oct 05 2015
    Billings, MT
    Mine has that issue as well, and that is what I have to do to fix it as well, plus distance issue.
