Results 1 to 20 of 20
    May 10 2008
    PA
    Building a 1.8T Engine
    Im currently attending UTI which some of you might have heard of. I currently have a 96 2.8 V6 and over the course of my time at UTI I want to build my own 1.8T to swap into my B5 when I have enough knowledge. Basically I want to know when building the motor what aftermarket parts would get me the most power and bang as far as manifold, cams, cam gears, turbo and intercooler and other parts i haven't mentioned.
    Feb 27 2005
    North Wales, PA
    Re: Building a 1.8T Engine
    Quote Originally Posted by tmljeh19 View Post
    the 1.8t forum on vwvortex has tons of reading material. Since you are in school, it would be best to read, learn, and come up with your own plan. When you have specific questions that you can't find an answer to, then ask. Asking generic questions will get you generic or biased answers.
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    What turbocharger do you want to run?This will allow us to assist you with the best bang for buck mods possible.
    May 10 2008
    PA
    Quote Originally Posted by Issam@034 View Post
    I have no preference. I guess maybe a better question would be what parts on a stock 1.8T are upgradable?
    Turbo
    Intercooler
    Manifold
    Throttle Body
    Cams
    Cam Gears
    What else am I missing?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    RODS
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    EVERYTHING is upgradeable, and I mean everything for the most part. The only limit is how deep your pockets can go. Search is your friend, from the looks of it you have no HP goals or anything, figure out what you want out of the car and go from there.
    Apr 22 2007
    Riverbank, Ca
    Really you dont need anything except a good intercooler, RODS, and a big turbo (with supporting hardware such as boost controller, diverter valve, injectors, exhaust, flowing intake).
    What are your HP goals?
    300?
    400?
    500?
    600?
    700+?
    Its all in what turbo you use.
    Feb 26 2006
    Earth
    K03S?
    You have to have a preference.
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    How about we get back to basics- How much power do you want, what sort of powerband are you after, and what are your uses for the car (street, highway pulls, autox, road course, drag, etc) .
    We need some info to tailor our suggestions to your case, rather then simply pointing you to the engine parts section on one of our websites and telling you to buy it all starting with a and ending at z. :)
    Pete
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Registered Member Two Rings
    Apr 13 2008
    Westlake, OH
    I think it may be a better idea to start with something other than a 1.8.... possibly a 2.0 or a vr6?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    300hp is a good mark to shoot for, but it's your call.
    Read through a lot of the engine builds and see what you're getting into. Knowledge is power, power and knowledge are addicting.
    First and foremost, is this going to be a daily driver, weekend toy, or track car? That'll put you in the right direction.
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by FACT View Post
    LOL
    Then you can throw the VR6 in for him.
    May 10 2008
    PA
    Ok i want an HP output of between 400-450. 400 and above would be real nice to me. Its basically a DD but I wouldn't mind having it drag once in a while. My school sponsors a drag event twice a year and going sometime and being about to put down nicely would be my goal. Like i said 400 or about would be my goal for HP.
    Since basically since everything is upgradable what is the best parts to upgrade to give me that much output for a DD/occasional drag running. I want to stay away from nitrous altogether.
    As mentioned above what size/brand turbo would be best for that gain?
    What brand FMIC is better then others?
    Who makes good upgraded rods?
    What size/brand injectors are recommended?
    What kind of intake is best?
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Look into other threads here. Few people are building engines now.
    Parts list (just parts) to make 400hp
    gt3071....................1100
    spa manifold.............460
    wastegate...............230
    630cc injectors.........260
    tune.....................~800
    3" catback...............750
    hfc.........................250
    fmic........................900
    scat rods.................400
    Calico Rod Bearings....80
    main bearings............60
    piston rings..............150
    main bolts................20
    walbro 255...............100
    innovative xd-16...... 400
    greddy profec-b........400
    misc....................~1500
    sb stg 4 clutch.........600
    total of ~7100
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Oct 29 2005
    10speed
    San Francisco, CA
    Custom FMIC is better than others since your setup will most likely be custom
    IE makes rods and so does Scat, IE is a sponsor of these boards though, might want to go with them
    Your going to have to at least run 630cc Siemens, once again, IE can get them for you
    If your asking what intake is best when doing a custom big turbo setup, you need to do WAY more research on how turbos work
    - Clint
    May 10 2008
    PA
    is it possible to leave the tranny i have in there? I want to keep it auto since i hate being the only one able to drive my car.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    that is going to be extremely costly but not impossible. i know they make valve body upgrades (level10) and one of the audizine advertisers makes trannys for auto i believe but 400hp is quite a stretch. thats going be to be quite costly to make it hold that power
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    You don't need a 3071R to get 400chp. Its a sure win, but not needed.
    Walbro's also die. Get a Bosch fuel pump.
    Quote Originally Posted by Nebone View Post
    total of ~7100
    -Doug
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    it's a tip? if I were you, I wouldn't want any yahoo to drive the 400+whp car I spent a shitton of time perfecting and building. But it's a lot less work keeping it auto i guess.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Oct 29 2005
    10speed
    San Francisco, CA
    Our tip transmissions are the slowest things in existence. your going to need a bottom end out of an automatic because the cranks are different.
    Do you have $8k?
    - Clint
