Results 1 to 8 of 8
    Senior Member Three Rings Iosilver's Avatar
    Sep 20 2007
    2001.5 Slow4
    Winter Park
    Car won't start!!!
    Drove the car to a friends house an everything was fine but when i went to leave the car wouldn't start. The battery is fine but i have no vag so no codes sorry. The lights work an nothing fades or get's dim. Any clues where to start or anyone with a Vag in Orlando, FL that can help me.
    EMpTy WaLLeT
    STaGe: ToTaLeD
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    Re: Car won't start!!!
    this post is excellent. a car that doesnt start, but no info. oh, where to start.
    check spark, check fuel (pressure and volume), check compression, check for any DTCs....you know...like you would with any car?
    Active Member Three Rings turboquattro068's Avatar
    Mar 20 2005
    99.5 Audi A4, 99 Honda CBRf4
    Upstate, new york
    lol, also, did you pay your car payment, we shut cars off all the time when we have to repo them
    Sep 20 2007
    2001.5 Slow4
    Winter Park
    Thanks, anyone with a Vag in Florida close to Winter park that can help? Car was paid off the day i bought it and drove it home from Ohio, thanks for some laughs guys.
    EMpTy WaLLeT
    STaGe: ToTaLeD
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Hey man,
    I'm sure its frustrating but does it turn over and not fire up? or is it not even turning over? that info will help diagnose the problem
    Check to make sure its getting fuel and spark. When you turn the car over have someone stick their head in the trunk and listen to hear if the fuel pump is running.
    Check fuse box to see if any fuses were blown for some reason.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Sep 20 2007
    2001.5 Slow4
    Winter Park
    I will check the fuse box tomorrow and i guess have someone listen in the trunk. I just replaced my turbo's maybe 600 miles ago, so it's gettin to me. It doesn't turn over at all starter or spark plugs maybe. I also had a trans sensor replaced i think it was a (neutral safety switch). Does the palm pilot that works like a vag tool work as well as the Ross tech cable? Thanks for the input
    EMpTy WaLLeT
    STaGe: ToTaLeD
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    So it wont turn over. that kind of rules out listening in trunk for fuel pump because my guess is if it turns over it will start, so its probably getting fuel and spark.
    I would check that sensor that was just replaced. the trans sensor. I was going to suggest looking at that anyway. Not sure if car is manual or auto, but if manual it should be under dash by clutch pedal. (you probably know where it is)
    If you have an auto try moving it from park to neautral a few times and try to start it, maybe it didnt set right.
    If I were to bet, I think it has something to do with that switch. Why did you have it replaced?
    I'm also not sure if that cable can be used the same. You need the odb-II cable. I bought a cheap one off ebay and have the older version of vag-com. If you get a cable I can email you the software to use with your laptop.
    when you turn the key, does it do nothing? Is there 1 click? If a single click that tells me the starter is trying to engage but wont turn. If it just clicks continually, that usually means battery too dead to start.
    If no sound what so ever that usually means the safety mechanism is overiding the starter. So I would check with that.
    Well hope this info helps.
    Sep 20 2007
    2001.5 Slow4
    Winter Park
    Yeah just one click so mabe that safety switch, I'm goin to try and get someone to vag it. It's a 2001.5 tip i put some k25/k26 hybrid turbos on there so maybe the Tc went will that put me in a limp mode? Thanks for your help brother.
    EMpTy WaLLeT
    STaGe: ToTaLeD
