Results 1 to 9 of 9
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Ok i settled on some new wheels over the ch's
    19 x 8.5 iForge TE-14 's Matte Gunmetal Grey
    The time attack stripe is a tad thick but its vinyl and can be removed so .
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Re: Ok i settled on some new wheels over the ch's
    Damn!!! Looks good!!!
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Hot.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Stripe is way too thick... remove that vinyl. Nice wheels though man.
    B7 S4 Avant
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    the red is growing on me but will definitely be a thinner line when redone
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    Looks real nice....the red sticks out but it looks good..
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    very nice, but the red is thick
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Quote Originally Posted by BlackS4TT(Josh) View Post
    +1
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Loose the red and you have some hott wheels.
