Results 1 to 7 of 7
    Sep 16 2008
    San Jose, CA
    Horrible beeping problem?
    first of all, i did use the search button. i could diagnose a problem
    when i start the car. it beeps. close the door. it continues to beep. on the cluster i see the oil service sign flashing. i have changed the oil- would i have to reset that system?
    after about a minute, the oil service light is off and the beeping continues.
    when i turn on my head lights. oh my! the beeping turns into a constant beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep! for a good couple mins.
    finally it turnes into a beep........ beep. about 2 seconds in between.
    the whole process last about 5 to 6 minutes. the most annoying 5 or 6 mins ever.
    please help, maybe i can just eliminate all beeping all together. attack the fuse?
    thank you
    - oh and when i have the cabbin light on- the noise dissapears. but as soon as the cabbin light is off. the noise continues
    Aug 13 2008
    Indiana
    Re: Horrible beeping problem?
    I'm thinking it could be an ignition switch problem. Reset the oil light and go from there though.
    Dec 05 2007
    You need to reset your service interval. That should remove the beeping for the oil. And the beeping of the headlights sounds more of the warning of when the doors are ajar and headlights are on. I would look into those connections.
    Resetting interval for pre-facelift (though the write up says 98-99, I will assume it is for prefacelift)
    Resetting service interval light for facelift (though it says 2001-?, I will assume it is for facelift)
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Or/And he could have LOW oil pressure.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jan 19 2008
    Quote Originally Posted by nebone22 View Post
    Oil pressure isn't checked at idle though...
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    Maybe the door ajar sensor is getting messed up, since it happens when the headlights are on.
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Sep 16 2008
    San Jose, CA
    ^^ maybe. the car was involved in an accident the door was replaced. didnt look like they did the greatest job ( i got the car after the accident)
