so my front passenger window regulator is shot..ok
after i installed it i went to put my window motor back in and it doesnt even spin when i put all the power plugs into it..like the door chime sound comes on and the footwell light comes on..but the window motor and door lock dont even work..i even CHANGED the window motor but no power..
HOWEVER..if i try to use the driver side window motor it spins..is there a fuse for our doors?
and what brake pads would you guys use that are better than hawk hps? im still using the stock caliper/rotor setup and the hawks are worn out now
