Results 1 to 16 of 16
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Independent Fog Lights on Pre-Facelift?
    I have searched and can't find anything for pre-facelift cars... Can someone point me in the right direction?
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    Re: Independent Fog Lights on Pre-Facelift?
    May 04 2008
    Columbia, SC
    Will try that... Gotta read it a few more times before I attempt it though... What's wrong with pictures? lol
    Dec 05 2007
    Do you have fog lights? Are you trying to make your existing fog lights work independantly, or trying to place fog lights that your vehicle currently does not have?
    If it is the latter, then just get independant fog lights and hook them up. Instructions should be in the kit. I have never hooked any up myself, but if they work like any other luminare then it should be rather simple. It is just a light switch. If you get a kit and need help, I can try and assist.
    May 04 2008
    Columbia, SC
    I have fog lights in the headlights from the factory, but I was adding aftermarket fogs that I want to run off of the factory switch... I don't want another switch, but I also want them to run without the lowbeams...
    Veteran Member Four Rings Yevmeister's Avatar
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    just get a relay kit, and tap it into the green wire on the headlight which is headlight fog i believe
    Yev
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    I tried the above instructions. Tapped into the main fuse box, jumped wires as it said, but no luck. Fogs still only work when lights are on, but actual light in switch will come on at any time regardless of fogs actually being on or not.. To redeem myself I made a hidden switch for the headlight washers to work independent of lighting (anyone in the snow states knows why) :-)
    Sep 11 2007
    Dirty Jersey
    Quote Originally Posted by BADB5A4 View Post
    I made the opposite, I have a switch to turn mine off when I don't need to wash the headlights to save fluid
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    May 04 2008
    Columbia, SC
    Finally decided to try this and no luck... I got the same results as BADB5A4. The light on the switch would come on without the headlights being one, but the lights themselves wouldn't unless the headlights were on.
    Has anyone successfully conquered this task?
    Dec 19 2007
    Colonie NY
    Hey just a guess, does your rear for work without the lights being on? I just found out mine does . Both switches will illuminate but only rear for will be on, even without the driving lights on.
    Its got to be one simple wire, I think my car is taunting me at this point..
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    seems like too big of a task for such an insignificant result.
    __________________
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    I did the "independent" mod to my foglamps last week.
    I've got OEM RS4 HID's fitted to my '96 pre-facelift.
    Just pulled out the relay under the steering column area - behind the glove box on your LHD car.
    It's relay #7, I rigged up a couple of lengths on wire, fitted male spades at one end, and plugged them into socket 87 and 30 in the now vacant relay space.
    Then I fitted an inline fuse holder, with a 15 amp fuse, then clipped the holder into the main fuse box area. The wires should be long enough to reach your fusebox, to enable easy replacement.
    That's it.
    Now my front fogs work with my sides, dip, and don't switch off when I select main beam.
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Looking at doing this soon.....
    Siena, so do you fog lights work without the headlight switch in the on position??
    ~Brian
    1998.5 A4 2.8QT
    Established Member Two Rings da1nonlymikeo's Avatar
    Feb 02 2009
    mn
    http://forums.fourtitude.com/zerothread?id=3093160
    follow that. and here are some pics I took myself.
    WHY IS THERE NOT A DIY FOR THIS YET@!?? I would be glad to make one for you b5 owners but I dont have permission to post in the DIY section?
    Oct 22 2006
    Quote Originally Posted by da1nonlymikeo View Post
    WOuld this work on Canadian cars with foglights as DRL?
    Feb 02 2009
    mn
    Quote Originally Posted by karmad View Post
    no i theres a separate way to do that. im not sure of it. I saw a DIY for it once.
