Results 1 to 40 of 59
    Senior Member Three Rings 4 black rings's Avatar
    Mar 11 2008
    West Menlo, California
    Photos of customer stereos
    Anybody have photos of custom stereo in the B7 A4? if so share some pictures I am looking for ideas. Thanks
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    Re: Photos of customer stereos
    Here's some minor work I had done - btw, it is getting DAMN expensive to do any sort of custom stuff nowadays....the times of dropping a new head unit into a universally sized dash are O-V-E-R! As such, shops must charge much more for labor in general now.
    Mounted, audio/power hard-wired portable Sirius Stiletto (best mp3 player/device EVER):
    Custom molded fiberglass stealth enclosure for a 10W7:
    This pic shows how far up the side of the trunk area the enclosure extends behind the trunk lining:
    a JL 500/1 mounted on the underside of the rear deck-lid where the rear sub and speakers are mounted:
    (view from back seats with section folded down)
    (another angle)
    Apline bass gain adjuster (mounted in small slot just below the steering column):
    Overall trunk view to show the space saved:
    Enjoy!!!
    Deactivated Three Rings
    Dec 30 2004
    Palo Alto
    I'll give you a list of my stereo set up as of right now I have no pics.
    Alpine W505
    Alpine PDX1.1000 amp for subs
    Alpine PDX4.150 amp for components
    Focal 165 KR component speakers
    JL 10w6 subs in a custom made fiberglass box.
    Feb 29 2008
    Got it done at Rolling Thunder in San Rafael, CA - I used to bring my old car there way back in high school for work, but it was a much different shop then. On that note, like I said before, it's a much different industry now, too. Places like this are hard-up for business nowadays because of the way dashes are being built, and there really is no such thing as a $400 drop-in head unit job anymore. While this looks like a very simple, non-flashy setup, it was definitely costly - I won't give numbers, but I could've had STaSIS C/O's installed, a ecu flash done, and still would've had some spare money left over for a Carbonio intake or something comparable.
    However, I used to have what JL calls the Hi Output Enclosure for that sub, which took up 60 - 70% of the trunk space in my old car. It didn't even fit laterally into the A4 trunk, so I was forced to go with something stealth because the only other box that fit was VERY small and would've been a serious downgrade in sound quality. At the same time, I'm a huge snow-sporter and needed to maintain both overall space and the pass-thru to the cabin of the car when the seats are folded down.
    Here's a pic of the enclosure from JL:
    This is the one I just couldn't go with:
    Senior Member Two Rings DrewBo's Avatar
    Sep 18 2006
    OBP 2.0T
    Michigan
    I would love to install one of my subs that is sitting in my garage in the cubby area but between the cost of fabrication and installation, it's probably going to remain in the garage
    05.5 A4 Ocean Blue Pearl
    Veteran Member Three Rings volcomic's Avatar
    May 10 2008
    B9 A4
    Kirkland, WA
    Quote Originally Posted by B7A4Sport View Post
    It's actually quite the opposite. The HO boxes are built primarily for volume. They're great for rap or anyhting with very "boomy" bass, however the smaller sealed boxes from JL have vastly better sound quality. The W6's & W7's love to be in small sealed boxes for their peak performance. With a smaller sealed box they can take more power, and will hit super hard and clean. You really can't go wrong with a JL sub in any enclosure though...
    Here's a peek at my investment in premature hearing loss:
    ◊ 20x10 Avant Garde M590's - Brushed Clear ◊ 255/30-20 Hankook V12's ◊ H&R VTF Suspension ◊ APR Tune ◊ ECS Luft-Technik Intake ◊ ECS Carbon Fiber Front Lip Spoiler ◊ ECS Carbon Fiber Grille Accents ◊ Color Matched Reflectors ◊ 15% Tint ◊ 2 JL Audio 12w6V2's ◊ JL Audio 1000/1 Amp ◊
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    hehe, you guys are hardcore. I wish I had mounted the amp up there, but doesn't it get hot?
    I roll ghetttooo:
    *see sig for details
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    That stereo box is held down by hopes and dreams
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Feb 16 2008
    Honolulu, HI
    lol, you know it.
    DUH! an Audi
    los angeles, CA
    one day ill have a baller system!
    subscribing..
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    I just have a weak amp and 2 10"s that were on the car when i bought them. Not bad i guess, but im not much into systems.
    I have a Kenwood Navi screen that i had on my celica, was thinking of putting that in, cause i think its a lot better then the RNS-E. Its just cool cause i dont have to buy updated map cd's every year. and the fact that i can put dvd's in there is cool and its a touchscreen. Just a lot easier to use then the stock navi one. The only thing that i like about the stock then my kenwood, is that the SD card slots and the steering wheel controls. I use those more then i would the nav or dvd so im going to stick with it.
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Established Member Two Rings hmmd's Avatar
    Feb 07 2007
    2005.5 A4 2.0T quattro
    el centro, california
    everything else is stock
    ha haa! dangly parts
    Feb 29 2008
    Quote Originally Posted by volcomic View Post
    Hrm, I was under the impression there are pretty strict air-volume parameters that define both the loudness and the sound quality......like there is some wiggle room, but if you deviate too far from the defined measurements it'll degrade both aspects. Not to mention, I heard that little black box, which both sounded like crap AND is pretty ugly in my opinion.
    I do, however, notice that the crispness of a drum kick is much better out of the fiberglass enclosure, which is undoubtedly smaller in volume than the HO box (I listen to all types of music, from rock to rap to electronica). I attribute that partly to the sealed (vs. vented) enclosure that's made out of a more resilient material in fiberglass, and the overall interior cabin of an Audi is more sealed than my old ride. Thanks for the pointer tho, and you have a sweet lookin' setup! Any chance of gettin' a pic without the trunk sheet pulled over your stuff?
    Nov 16 2007
    Westerly//Providence
    Quote Originally Posted by hmmd View Post
    oh my lord...my hero....haha i have a 12" L5 and a 600watt rms alpine amp powering it.....im so jealous of your setup.
    edit: hows the rattle on that setup...mine rattles pretty good.
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Wow! Your running these on the stock amp!!! I must say........
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Feb 07 2007
    i guess i shouldn't have said everything else is stock, this is what they're running on
    Feb 07 2007
    Quote Originally Posted by CoreyRandmetz View Post
    yeah, these rattle pretty good, these are the L7s running on that soundstream amp i posted above
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    I'm running a alpine 9887, front comps are Hertz 165's with a Sundown 100.4 amp for the front and a Sundown 1000d for the Digital Designs 9510g sub. its rated 1500 continuous max output is 6000 watts on the sub. The sub alone weighs 50lbs plus another 45lbs for the box which is tuned to 40 hertz.
    Specs on the sub are here in-case you didn't believe me about the 6000 watts!
    http://www.ddaudio.com/dd/caraudio/w...p?series=9500g
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Four Rings CONTROL TWO's Avatar
    Oct 01 2006
    Cayman S
    SJ
    -Grant
    ig: g_strachan
    May 10 2008
    B9 A4
    Kirkland, WA
    Yeah, I listen to pretty much everything too. I found that the smaller sealed box (a seperate chamber for each sub internally) just hits so much cleaner, and harder than a ported box. I get very quick response which is needed for things like hard rock with a fast repetative kick drum (where a ported box just sounds like constant rumbling bass as opposed to seperate clean beats). If you run enough power, and have good subs, a sealed box also sounds amazing with rap, and will still hit really low without any hint of distortion. Here's a couple more pics of the set-up:
    Had to make everything "quick release" with handles on the box so I could use my "Avantness" if I ever need to
    Dec 18 2004
    houston, texas
    lawl.
    mattchow -- 2015 vw golf sportwagen + 2010 vw apr k04 gti (for sale!)
    Jan 06 2008
    Dacia Sandero
    Arizona
    Love those stealth JL boxes!
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    DUH! an Audi
    los angeles, CA
    soooooo jealous, love the jl audio black edition amps :: hail ::
    Mar 11 2008
    Where did yu get the JL Stealth Boxes they are not on the JL website?
    Thanks
    Feb 29 2008
    Quote Originally Posted by 4 black rings View Post
    Thanks
    Mine isn't from JL actually, which would explain why you can't find it, lol.
    It is a custom-made fiberglass enclosure that was shaped/installed by taking an exact mold of the space between the outside sheet metal and trunk liner in the rear fender/quarterpanel area (behind what people term the "cubby hole" that also houses the satellite receiver). Then, a few layers of Dynamat were placed on the inner face of the sheet metal for reinforcement, and it was finished up so all you really see is the woofer face sitting flush with the trunk lining.
    The shop I went to is just top-notch (Rolling Thunder in San Rafael, CA), and they have a great crew. One of the guys who worked on my car actually drives a B6 S4, and had already done a similar molding for a B7 A4; although it was not for a W7. This work is not cheap - all materials and labor for the install of the box was about $1,400.
    Anyone familiar with the magnet/voice coil assmebly on that sub knows it doesn't fit in to any small holes easily!
    Mar 11 2008
    so do you have 2 cars one wagon and 1 sedan. You were the same person that first replyed to the thread right?
    Senior Member Three Rings Stak3407's Avatar
    Sep 27 2007
    2006 Audi A4 Silver
    Munster IN
    Quote Originally Posted by Turn10 View Post
    It must be because I'm at work but this had me cracking up!!
    APR 93, Magna Flow Custom Exhaust, Stasis Coilovers, Velocity 18" Rs4 replicas, OEM S4 Door Blades, Votex Chin Spoiler, Votex Rear Spoiler, Painted Rear Valence
    Veteran Member Four Rings swoardrider's Avatar
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    '06 2.0T S-line Tip
    Stasis/Ohlins Motorsports, Stasis 14.5" BBk, Stasis rear BBK, H-sport rear sway, JHM 2+ tune, JHM 4:1 center diff, 18" Wed'sSports w/ 255/30 Toyo R888 (track), 19" Tenzo-R's w/ 255/35 (street), Stern upper arms, upgraded stereo, Huper tint, RS4 grill, JHM HFC, JHM downpipes,OEM S4 exhaust, track goodies
    Mar 11 2008
    BUMP!!!!!!!!!
    Sep 02 2008
    Boston, MA, USA
    Quote Originally Posted by swoardrider View Post
    Damn, seriously the cleanest install yet. What amp is that? It could pass as factory from that view.
    Active Member Four Rings
    Dec 11 2006
    Boston
    I've never felt a sub hit harder than a 13w7.
    I saw in a hummer with four 12" eclipse subs, very well done. But compared to the two 13w7's that I heard. It just didn't compare. My chest literally hurt after I got out of the JL car.
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    Quote Originally Posted by deb38 View Post
    Which is why install has more to do with than anything else.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Quote Originally Posted by yettavr6 View Post
    Zapco DC360.4 - I specifically went with this amp because it could be mounted upside down due to the internal fan and the wires are all concealed due to the front mounting terminal design. Another plus is that the amp is tuned by using a laptop and Zapco software.
    '06 2.0T S-line Tip
    Established Member Two Rings Element's Avatar
    Aug 09 2008
    New Jersey
    Damn nice stuff in here and are all these cubby installs custom boxes?
    May 10 2008
    B9 A4
    Kirkland, WA
    Quote Originally Posted by Element View Post
    Yeah
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    twin 12 inch thousand watts
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Feb 29 2008
    Yeah
    x2
    Wonder why JL doesn't make A4 stealth boxes (I'm going off a very rough memory w/ that comment, however).
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    im no professional, but how would the sound be different if our subs were turned around and faced towards the front of the car. i have a ported box that pushes out a good amount of air and with the back seats down i think that would be cool. i havent been able to try it because i dont have long enough cable to make it work.
    May 04 2007
    Northeast
    How did you mount your amp to the top of the trunk? Do you have more pictures of the amp install? Looks great!
    Mar 03 2008
    Washington
    x2
    Probably because the demographics they use show that the majority of A4 owners aren't interested in such a product.
    Also, from my understanding, it is quite expensive for the R&D of those boxes. They need to be sure that their rate of return will be a net positive for the company, otherwise the execs. won't give the go ahead.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    Mods = 0
