Results 1 to 21 of 21
    Veteran Member Three Rings UBERS4's Avatar
    Sep 18 2006
    2005 Arctic White S4
    Earth
    Dropped and rubbing...
    I finally got my coils set where I want it and I'm getting a little rubbing. I removed the 12 o'clock bolt and that helps but it seems at higher speeds, I still rub. My wheel offset is not the problem and I'm running 235/35/19 tires. I remember seeing something about thinning the felt in the rear fender. Can someone attest to that?
    My car is currently getting an alignment so maybe that will help out a little. Any other ideas would be appreciated. I'd really like to avoid raising my coils up or rolling the fender if possible.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    |Dunlop Tires|DPE Wheels|Oettinger|Rotora|Tein|GIAC|Supreme Power|
    Deactivated Three Rings
    Apr 11 2008
    Re: Dropped and rubbing...
    You must be dumped pretty low to have rubbing issues. What offset are you running, anyway? I have 38et with same size tires and rub only on big bumps/dips (i think) but is very minimal.. from what I understand, you won't get much more out of rolling the fender on a b6
    Established Member Two Rings ichibunz's Avatar
    Jun 03 2008
    Danbury,CT
    i have the same tire size but no rubbing at all...what's your ride height? I run 25" ride all around with 19's no issues and 35ET.
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    What is your ET and ride height?
    Some negative camber might help your rub.
    Registered Member Two Rings hackers4's Avatar
    Jun 12 2007
    Miami, Fl
    Size and offset of wheels? Also, what brand of tires are you running?
    2005 Audi S4
    MTM Fullback Exhaust
    ASR Engineering Test Pipes
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stasis Center Differential
    Stratmosphere SS
    BBS RS-GTs
    Sep 18 2006
    Earth
    I just got the car back and good news, the alignment helped the rubbing. From the sounds of it, no problems over dips, railroads, hills, etc. BUT, I now have come across a much bigger problem.
    In a nutshell, I have developed some severe tire wear on the inside of my front tires. When the dealership told me, I thought they were BS'ing me but sure enough, I'm seeing threads. I'm totally puzzled on how this has come about. I got my coils on and set about 6 weeks ago. I let them settle and went in for an alignment today. I MIGHT have put 1,000 miles on them over the last few weeks. As you can see in the picture below, I got mad tire wear and the front tires are pretty much shot. My toe and camber was off but there's no way it would have harmed the sidewall like it did. My question is where could the culprit be coming from? Am I rubbing something suspension wise that I can't see? Could it be the fault of a poor install? Regardless, I need new tires. I just want to make sure that once I get new ones on, I don't have the same issue.
    Also, for you guys who are lowered heavily, have you noticed any pre mature tire wear?
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    You'd be surprised at how quickly tires can wear due to incorrect alignment. If the toe is off the tires can scrub really badly, and if the toe was off with the tires pointing in you could have easily worn the tires through to the ribs in the 1k miles you drove the car.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Jun 13 2008
    02 b5.5
    looks like you hit the pinch bolt/ steering knuckle on the inside, I have 19x8.5 with 235/35/19 up front and had to space it out because it was way to close.
    Sep 18 2006
    Earth
    Quote Originally Posted by swaigo View Post
    That would make sense. Could you elaborate a little more on what you mean by spacing it out? Do you mean you had to install spacers?
    Thanks guys. You've been a good help so far and I'm getting closer to sourcing the issue.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Established Member Two Rings cops04s4's Avatar
    Jul 06 2007
    04 Nogaro Blue S4
    South JerseY
    Damn Im about to install my coils on friday, And will be running the same size wheels and planned on going low... Spacers might work...
    Established Member Two Rings cucubee5's Avatar
    Oct 30 2006
    B7 A4
    New York, New York
    Quote Originally Posted by UBERS4 View Post
    Woah! I've never seen that before.
    Can you take more pictures of this?
    Jun 12 2007
    Miami, Fl
    I've never heard or seen anything like that. What is the offset of the wheels you are running. No matter how close you are to the knuckle, it won't hit if it doesn't rub upon install; it moves with the wheel/tire. That had to be alignment or the offset is incorrect and THEN it will rub on the knuckle.
    2005 Audi S4
    O.CT Chip
    EVOMS Intake
    H&R CO
    H&R Sway Bars
    Stratmosphere SS
    BBS RS-GTs
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    With the camber off for a 1000 miles, it can for sure chew through tires like that.I usually let the car settle for a couple days and then go get it done.Maybe a 100 miles tops but more likely 60-70 miles.
    Sep 18 2006
    Earth
    Quote Originally Posted by Monchichi8 View Post
    Agreed.
    Here's an update guys. I went to my shop and he said it does not look like I'm rubbing on anything important or at all. He stated the same thing above, if the toe/camber is off enough, wear wouldn't be uncommon. Regardless, I need new tires and they will be here shortly. I then will get things realigned and let you guys know the final outcome.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Senior Member Two Rings mystro's Avatar
    Apr 29 2005
    Woolrich Pa.
    I would like to see a pic of how low you are dropped.
    Sep 18 2006
    Earth
    Quote Originally Posted by mystro View Post
    I'm low but I've seen people lower. My Teins could still go lower but I'm happy with the ride height.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Active Member Four Rings HOFFY11's Avatar
    Aug 01 2008
    Audi A6 4.2L Quattro
    forked river, NJ
    ohh boy..minus the stickers on the front bumper..i would say that is a savagely sexy looking vehicle =D
    Sep 18 2006
    Earth
    *Update*
    I got my new tires on late last week and finished up the alignment and made sure everything was set. I drove to and from HIN Minneapolis (around 650 miles) last weekend and since then, no problems at all. Rubbing has pretty much gone away (still some slight rubbing over big bumps at high speed but I'm super low) and the wear seems to be good. I plan to go into my shop and have them look just to be 100% sure but all looks well. FYI, I am dropped 24 1/4 inches from the fender to ground.
    So the moral of my story is to get an alignment immediately, especially when you tinker with your suspension. Even though my tires should never have worn like they did, this situation might have been better off if things were done a little differently. I still need to tweak some things in order to stop scraping entirely but at this ride height, it might just come with the territory.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Nov 04 2006
    05 S4
    LI, NY
    24 1/4".....WOW thats low. Question.....do you have camber adjustable upper control arms in the front??? Because at that height I can tell you now that your camber is wayyyy off and you might end up needed some new tires real soon again.
    Inside and outside edges can also be worn by aggressive driving. Taking hard turns alot like parkway off ramps and the twisties really do a number on the edges. AND the softness of your tire will make a contribution.
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Quote Originally Posted by HOFFY11 View Post
    I agree, but if I'm not mistaken, his car is sponsored. Here you go though...nice ride!
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Sep 18 2006
    Earth
    Quote Originally Posted by ant7701 View Post
    I have the OEM control arms. I had an alignment already with the new tires on and all the numbers came out fine. But, I wasn't happy with the way things were done so I'm going in again on Tuesday to another shop.
    My main concern right now to eliminate any and all rubbing. The fronts are fine but the rears could be better. We'll see if this next alignment helps as my only options would be to run negative camber (something I obviously don't want) or raise my coils up enough so they just barely don't scrape.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
