Results 1 to 8 of 8
    Registered Member Two Rings
    Aug 14 2008
    07' A4 2.0T
    Marina Del Rey/Malibu, CA
    Audi Service Code
    How do you get rid of the Audi Service message on the dash, went to the dealer and they told me it would be 650 dollars to get ride of it, is there a certain code you can use to get rid of it? Being that I've owned my car for 6 years and there's only 30k miles on it, there all off on knowing when my car needs to be serviced.
    Have 02 A4 1.8T Manual
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Audi Service Code
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Dec 03 2005
    2 pedals 1FG
    connecticut
    A 2002 with 30k? Wow. My 2002 has 130k
    You are fine until about 50-60k. At 60k you should start thinking about a timing belt.
    If your car was stored in LA the whole time I don't think you should have a problem with the timing belt and serpentine belt dry-rotting.
    Change your oil every 5k or 4 months and you should be alright.
    -Doug
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    30k is crazy, I just passed 100k the other day..
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    It's actually in the manual...
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    650 to get rid of the service code I would report this dealer IMO.
    05 Triple Black 1.8T Quattro Tip.
    May 21 2007
    Florida
    ^^he probably means they wanted to do a service on it, which cost $650.
    2018 Navarro Blue Q5
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by pondside36 View Post
    Yeah seriously. 91k here...
