Results 1 to 14 of 14
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    GIAC FXK03 dyno...question about peak torque.
    So I got my car dyno'd finally. I was curious to see what the numbers were.
    169awhp @ 4800 RPMs
    194awtq @ 4500 RPMs
    I noticed compared to other dyno sheets that my peak torque is quite late in the power band. Other dyno results I've seen almost are at peak torque around 3000-3500 RPMs for BI setups, definitely a big difference compared to mine. The guy running the dyno said I would probably benefit from a larger DP (currently stock DP, which I think is 2.25" to custom mid-pipe back, 2.5") and a TIP. Assuming my car is running fine, what could be done to move that peak torque to hit earlier.
    Two others to compare, both also GIAC FXK03, similar mods minus a DP.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Three Rings TurboQuattroPwr's Avatar
    Sep 28 2006
    Delaware
    Re: GIAC FXK03 dyno...question about peak torque.
    I put down 176awhp on Autospeed's dyno two months ago, so I guess your numbers are in line with that.
    2018 Audi S4 3.0T
    18% Tint, CquartzPro Ceramic Coating
    2002 Audi A4 1.8TQM *Gone*
    May 03 2005
    Boston
    Yeah the numbers are pretty much spot on for the setup but peak torque isn't compared to others. It's slower at getting there.
    EPL S2 + TCU
    Previous Cars:
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    downpipe will definately help
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Were the other cars running a FMIC?
    May 03 2005
    Boston
    The first one, yes, AWE FMIC. The second one, not sure. It only looks like one run was done or they took the best out of 3 runs.
    EPL S2 + TCU
    Previous Cars:
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    How about a boost log of your car.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    I think these dynos were performed in different gears than each other. The dynos' your comparing too were done with cars that have 5 spd tranny's while yours is a 6sp. So again, the difference is in which gear these dyno's were done.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Jan 10 2007
    VA
    You should see near peak torque beginning at ~3000rpm and then it plateauing until about 5000rpm. At 3000rpm your graph is only showing 125ft/lbs of torque, while the other graphs are showing both showing about 160ft/lbs.
    Looks like you are not fully spooled until past 3500rpm. The K03 should be spooled well before that. It looks like a much more gradual torque curve than most BI dynos have shown. Might be a dyno issue, might be your car.
    When you drive the car does it feel like the graph indicates?
    May 03 2005
    Boston
    Quote Originally Posted by actlsub9 View Post
    I'll see if I can dig one up. I did one about a month or two ago and requested vs actual was in line.
    EPL S2 + TCU
    Previous Cars:
    May 03 2005
    Boston
    Quote Originally Posted by RLB6 View Post
    True, I forgot about that. Mine was done in 3rd gear and the others were as well IIRC.
    EPL S2 + TCU
    Previous Cars:
    May 03 2005
    Boston
    Quote Originally Posted by b6onboost View Post
    The car pulls hard from about 3000+ (not like the dyno indicated), almost like it spikes and pulls to 5000 or so then runs out of breath.
    The gradual part was what caught my attention and the guy doing the dyno.
    Someone suggested I swap out my DV, still on the factory one but not showing any symptoms of a "bad dv". But I wouldn't think a DV would help that curve.
    EPL S2 + TCU
    Previous Cars:
    Sep 20 2006
    MD
    Quote Originally Posted by gdawg'05a4 View Post
    2003 5 spd 3rd gear ratio: 1.429:1 , final drive: 3.889:1
    2005 6 spd 3rd gear ratio: 1.423:1 , final drive: 3.889:1
    You're 3rd is not as aggressive but not different enough to cause your power to come on so late. Maybe a DV problem?
    May 03 2005
    Boston
    Yeah, someone suggested a DV problem. I'm going to order a replacement DV seeing as mine is still the factory one. It's been through about 70k miles on just a GIAC flash and then BI at 84k. Currently at 99,xxx miles.
    EPL S2 + TCU
    Previous Cars:
