So I'm not sure what is going on. Yesterday on my way home from work my car started doing some weird things. The transmission decided to downshift on its own a couple times (this while at cruising speed on the freeway). Also tiptronic stopped working, I can't use the shifter or the paddles to shift in tiptronic mode. Also on the cluster the gear select display is different. Usually it is lit red letters for P, R, N, D, S... however that has changed to a lit background and non-lit letters (see pic)
I checked the DTC's and get the following:
Address 01: Engine
1 Fault Found:
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - Implausible Signal
Address 02: Auto Trans
1 Fault Found:
002309 - Gate Select Position Circuit for Tiptronic (F189): Implausible Signal
P0905 - 000 - -
Address 03: ABS Brakes
2 Faults Found:
01314 - Engine Control Module
000 - - - Intermittent
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - - - Intermittent
After I cleared the DTC's the only one that comes back up is 002309 - Gate Select Position Circuit for Tiptronic (F189): Implausible Signal
Anyone deal with this before?I'm planning on taking it in to the dealer asap, just wanted to get some insight.
TIA
