Page 18 of 27 FirstFirst ... 81617181920 ... LastLast
Results 681 to 720 of 1065
  1. #681
    Jun 27 2011
    ^^ What year is your A4?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  2. #682
    Active Member Two Rings Kevboarder's Avatar
    Apr 28 2010
    Specalized Stumpjumper, GNU Pickle, Burton CustomX, sector9 sidewinder
    Shelton CT
    its a 2005 1.8t ultrasport, it seems to be a little of a 2004 and a little of a 2005 even though its after the vin split
    all motor is nice... but id rather be blown
  3. #683
    Veteran Member Three Rings AutoUnionLov3r's Avatar
    Mar 03 2011
    MK4 Jetta 2.slow-sold, MK4 GTI 1.8t-dead, TT225-sold
    Pittsburgh
    DIY - B6 1.8t - Vacuum line and Check Valve removal/simplification
    Anyone do this simplification and have fluctuations in wastegate response after deleting the N112? I'm not too happy with my part throttle response as it feels like my WG is been activated more than necessary. At part throttle I'll let off the gas, get a slight flutter, then it feels as if my car wants to squeeze out about 2 more psi as I hold my throttle about 1/4 way down. Is this from the N112 delete or possibly something else?
    Sent from my iPhone in my arse pocket using Tapatalk 2
    '04 USP
    Test Pipe, SAI Delete, Custom Intake, APR Snub Mount, 710P, Joey Mod Headlights.
  4. #684
    May 24 2010
    Sofia
    Hi,
    I've a little question. I can't undrestand why there is no check valve (after the simplification) between the brake booster and the manifold?
  5. #685
    Veteran Member Three Rings tehbry's Avatar
    Aug 12 2012
    Atlanta
    I really want to do this as I just did the N249 delete today but none of the pictures work :(
    I'm definitely not going to attempt this without the pictures, anyway I can get them to work?
  6. #686
    Aug 12 2012
    Atlanta
    Quote Originally Posted by tehbry View Post
    pweaaaaase
  7. #687
    Sep 09 2013
    Norway
    someone that have the measurements for the blockoff plate? like this http://www.uspmotorsports.com/Integr...T-Engines.html
  8. #688
    Sep 05 2013
    Ottawa, Ontario
    So if I read this correctly, It's better to run the DV off the Intake? So I should be able to just loop the N249 valve and leave it plugged and run the DV off the intake and I can also do the crank breather and valve cover breather mod while im there and shouldn't have any CEL? I have the APR system with 4 stages and k04 so I don't know if I the readiness is already done if i was to remove the SAI. Can anybody shed some light for me on this please?
    Thank you
  9. #689
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Retain the N249
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
  10. #690
    Jun 27 2011
    Quote Originally Posted by Timtheguru View Post
    Retain the N249
    I bypassed mine and notices zero difference. I did it to try and diagnose a weird boost hesitation that it did literally nothing for. I've been too lazy/don't car to hook it back in again though.
    -CP
    2017 Q7 3.0t
  11. #691
    Sep 05 2013
    Ottawa, Ontario
    Also, If I run some line from the intake to the DV, What size should I go with? because the original line running from the intake to the N249 is smaller then the line running from the N249 to the DV.
  12. #692
    Jun 27 2011
    Quote Originally Posted by K04-B6 View Post
    They should all move the same size. 4mm. That's what I used on everything.
    -CP
    2017 Q7 3.0t
  13. #693
    Sep 05 2013
    Ottawa, Ontario
    Oh ok perfect, Thanks for the help! If I have time this weekend I will give this a try
  14. #694
    Dec 30 2009
    You wouldn't but your turbo would, I would post a link, but it goes to the B5S4 forum... and people don't like it when I do that. Even though we have the same discussion about the N249, as it functions the same way for the B5S4..
    2001.5 S4 Sedan
    2018 Q5 2.0t
  15. #695
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    For what its worth here's my experience with the N249: Clicky click My advice is to leave it hooked up.
  16. #696
    Dec 30 2009
    Ah, what the hell. We even have graphs and shit.
    N249-delete-Why-you-should-not-do-it
    2001.5 S4 Sedan
    2018 Q5 2.0t
  17. #697
    Dec 28 2006
    Western Maryland
    Great link Tim! It confirms my measured mileage decrease with it disconnected. After reading that information I can see how disconnecting the N249 can take away some of the smoothness of operation and cause a bit of increased abruptness when on and off throttle. The increased abruptness can be interpreted as an increase in responsiveness whereas it is really more of a decrease in smoothing of the boost transition.
  18. #698
    Dec 30 2009
    Glad to be of service!
    2001.5 S4 Sedan
    2018 Q5 2.0t
  19. #699
    Sep 05 2013
    Ottawa, Ontario
    Sorry if this has already been answered but i didn't want to read through all these pages and find out this wasn't asked. With doing this mod will the crankcase breather still work properly since there is no longer a PRV valve? And also to prevent of having the SAI pump CEL light come on i would have to leave it plugged but what if I was to do a closed loop system with that? As in just run a line from the inlet to the outet straight on the pump.
  20. #700
    Jun 27 2011
    Never saw this until now. VEEEERY interesting. Considering I looped my N249 thinking it would solve my boost stutter, only to find out the real culprit was an Air filter with 96k on it , I might just re-instate my n249. I didn't really notice much of a difference after I looped it, but I've been mulling over returning it to stock for a week or two now that I've solved my intake restriction. Might have to man up and just reconnect it soon assuming I have enough vacuum hose to run the proper lines...
    -CP
    2017 Q7 3.0t
  21. #701
    Veteran Member Four Rings freeloader700's Avatar
    Mar 23 2012
    '03 A4 1.8TQM
    The Hills, OR
    Wow did not know that about the N249. I looped mine 8 months ago. I did feel a little more response or that the "throttle felt more connected" like OG said. I am getting 18-20mpg 50/50 city highway. Maybe this will help it out. I am sure though that my aggressive driving has a part to do with the mpg
    Looks like I will have to switch it back. Good info
    2003 A4 1.8TQM // Motoza // GTRS // 550cc // TR18T // Forge Splitter // 034 RSB & End Links // V710 Gunmetal 19x8.5
    →→FrankenTurbo F21 BUILD←←
  22. #702
    Sep 05 2013
    Ottawa, Ontario
    Anybody?
  23. #703
    Feb 12 2008
    Michigan
    When I bought my car all this stuff was deleted, the n249 valve is there and plugged into the wiring, but no vac lines are connected to it. How can I and what else would I need if I wanted to hook it back up?
  24. #704
    Mar 03 2011
    Pittsburgh
    Quote Originally Posted by Fast4esT View Post
    Read, figure out your exact hose configuration for your year engine and start ordering parts. Follow A4Darkness' post on "Engine Strengthening" to familiarize yourself with the needed hardware and shop smart.
    Sent from my iPhone using Tapatalk 2
    '04 USP
  25. #705
    Dec 28 2006
    Western Maryland
    Pretty straight forward. The line that currently runs from the front corner of the intake manifold to the DV needs to be rerouted to the N249. Then run a line from the N249 to the DV. Done. Here is a visual that may help: Clicky click
  26. #706
    Dec 28 2006
    Western Maryland
    You really do need to read through "all these pages" to get your answer. If you just start pulling out stuff willy nilly with no understanding of their functions you will be back posting "Why is my engine all f***ed up and misbehaving??????? Why do i have a CEL?????? Why does my idle go up and down?????
    This thread might help a little: Clicky click. Once you understand the functions of the various components you can make an educated decision as to what you would like to eliminate and what you need to retain.
    And to answer your questions:
    "Will the crankcase breather still work properly since there is no longer a PRV valve?" No.
    "And also to prevent of having the SAI pump CEL light come on i would have to leave it plugged but what if I was to do a closed loop system with that? As in just run a line from the inlet to the outet straight on the pump." No.
    Cheers!
  27. #707
    Sep 05 2013
    Ottawa, Ontario
    Cheers!
    Thanks for the help! I am new to Audi so I'm still learning abit about these motors. I have abit of mechanical knowledge since I do all my own work and used to work in a shop. I thought that this DIY was to remove all the useless vacuum lines and wouldn't cause any harm to the motor. I'm aware of what the SAI pump's function is but alot of people say it's useless since it only comes on for 90 seconds on cold starts.
  28. #708
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Audi did not put any useless line under the hood. They are have a purpose.
    2019 SQ5 Prestige
  29. #709
    Mar 03 2011
    Pittsburgh
    The SAI function is to pre-heat your catalyst to operate at optimal temperature for the sake of not ruining your secondary o2 sensor. Anyone can correct me if I'm wrong here but that is my understanding of the SAI pump. Do yourself a favor and keep all the vacuum lines and check valves. You'll thank us later for saved headaches.
    '04 USP
  30. #710
    Dec 28 2006
    Western Maryland
    The SAI pump works in conjunction with the 22° of intake cam advance to help get the catalytic converter up to temperature faster thus reducing emissions and increasing the longevity of the cat. It has no performance implications other than what I just listed. If you are running a test pipe the SAI system becomes unnecessary.
  31. #711
    Sep 05 2013
    Ottawa, Ontario
    Well I guess I'll leave everything alone then if it's only going to cause problems down the road, I'm planning on going with a 3" HFC and down pipe from Unitronics this summer. I bought the car last spring and it already had the fully loaded Ecu from APR, with injector and k04 so I wasn't sure what this mod could of caused.
    I appreciate all the input
  32. #712
    Mar 03 2011
    Pittsburgh
    A whole lot of good reading to be done here >http://www.audizine.com/forum/showth...-by-a4darkness
    '04 USP
  33. #713
    Established Member Two Rings Red Gumball's Avatar
    Feb 20 2012
    PNW
    Just completed this whole procedure without any complications. Drove just fine for a couple days and then noticed a CEL. Thought nothing of it since removed SAI. Then I started getting stutters out of the car under acceleration and only when at a warm temp. Checked the CEL and got a p0441 purge valve emissions code. Cleared the code but am still getting the stutters. I will say that instead of looping the hose on the n249 I just plugged all the nipples on both the n249 and n112. Would that be causing the issue?
  34. #714
    Apr 01 2007
    houston texas
    Quote Originally Posted by Red Gumball View Post
    Is your N80 still hooked up?
    2019 SQ5 Prestige
  35. #715
    Feb 20 2012
    PNW
    Quote Originally Posted by texasboy21 View Post
    Yes still hooked up and venting to atmosphere. I followed the DIY step by step.
  36. #716
    Jun 27 2011
    Hook your n80 back up properly. It's an integral part of the fuelling.
    Posted from my iPhone. Any misspellings are Siri's fault.
    -CP
    2017 Q7 3.0t
  37. #717
    Apr 01 2007
    houston texas
    Connect it back to your TIP and see if that fixes your problem.
    Yet ANOTHER 'I took stuff out now I have a CEL' post. When will people get it?
    2019 SQ5 Prestige
  38. #718
    Feb 20 2012
    PNW
    You must of not of read my original post. I know I will have a CEL. that I don't care about. READ my first post and you will see what I'm trying to figure out.
  39. #719
    Feb 20 2012
    PNW
    1) But I still am confused as to what i do with the EVAP purge valve. Doesnt that release gas-fume build up from the tank? That is obviously necessary.
    1) EVAP purge valve needs to stay connected to the line from the tank, the line that comes from the passenger fenderwell. Everything between the solenoid and the motor can be removed. It needs to stay plugged in and connected to the tank feed line in order to bleed off any fume or pressure buildup. if there is gas pressure in the tank it will vent on it's own. that's how equalizing pressures work. Taken from post #14
  40. #720
    Apr 01 2007
    houston texas
    The N80 needs to be connected to the TIP and intake manifold with a check valve inline. See my (older) pic below. Notice the white T running from the N80 to the TIP and back near the firewall. There is a good change your stumbling is from not having it connected properly.
    2019 SQ5 Prestige
