Well today I decided to finally get the car flashed. Drove over to 034 and it was flashed with the Uni file within 15 minutes or so. I drove away to find that the car pulled a couple times at 15psi, then started boosting like it was stock again, holding around 10psi.
I went back and asked Laszlo if the program was a 1bar, he said it should spike around 20-22psi. Definitely not getting that. He goes out, checks it out, him and another tech go drive and log it, the ECU is fine he tells me, so it must be a boost leak somewhere. He said they didn't have time to look at it as they were closing up, but I could bring it in tomorrow morning and have them look at it.
Well I'm not sure I can make it over there for a while, work kinda screws up my schedule and I'd much rather figure this out on my own. When I drive the car, it pulls a few times and holds 15psi, then it'll start to taper off to 10psi, until it will act like stock again, only holding to 10psi. This will happen untill I shut the car off, and turn it back on again. Which seems electronic to me, but what do I know.
There are no visible boost leaks at this point. But here are a few things I know of.
I replaced the L shaped hose 6+ months ago when I found a tear in it with a straight hose, that I was assured wouldn't cause any problems, which it hasn't. But now that it's pushing more boost, could this be that much of a restriction? It's definitely kinked a good amount.
Also, this breather hose tore 6+ months back as well, when I replaced it I clamped only the top two lines, as it was a PITA to get another clamp on the bottom line, and I was told that many VW techs themselves only clamp down the top two...
At this point, the turbo inlet pipe seems to be fine.
Laszlo's guess was the throttle inlet pipe, but that seems fine to me. Doesn't look like it's collapsed or anything.
I'm gonna take the bumper off and make sure all the intercooler pipes are secure, but other than that. I'm stumped. The first thing I thought was diverter valve or N75 valve, but I thought that was more of a thing that would wear out over time, not just fail right away. Any insight?
Here's some pics of my car from today as well for anyone who bothered reading all this
