Well for those of you that remember, this is my third post about clutches.
If you remember the second, it was about a body shop blowing up my clutch two months after installing it. Well I replaced that with a FE SS and kept the AWE LWFW that I put in with the previous clutch.
When I first picked it up it felt pretty high for a new clutch. After probably less then 5,000 miles, it feels like i need a new clutch. The car is stuttering while starting in first and feels really high. Keep in mind I've never launched it because I'm to paranoid about it blowing, that and the fact that I never really felt like it was right.
When I first put the LWFW in I held it up in comparison with the stock Fly Wheel and notices that it is a lot thinner then stock. I'm thinking this is the root of my problem and why my clutch feels so shitty? Because the clutch has to travel further to make contact?
Is there any way to remedy this? I can't afford a new clutch and it would be a stretch to put a new flywheel in it as well, if you can even do that without changing the clutch as well. Did they do something wrong when they installed it?
Please help because I'm freaked out.
