    Senior Member Three Rings BamfiNogaroS4's Avatar
    Feb 12 2008
    Denver, Co
    Wide body people come in
    I am buying some Iforged classic rims, or at least trying to but seeing how I am wide body I am not to sure on what to tell them for the size/specs? Right now I have 18x9.5in tire on them with adapters. My goal is to ditch the adapters and make it right again. I called them and I am sticking with the 18x9.5in but I have no idea on what specs to tell them? Can anyone help me with this???? On a side note what is the tire specs of a stock 2000 B5 s4 wheel as well?
    Oct 06 2004
    Minnesota
    Re: Wide body people come in
    Post pics of your widebody. Mine is mellow for a B5 with 4" flare in the rear and 3 in the front. I am running 18x10.5 rears with a 35mm spacer in the rear. Im 9.5 in front with a 25mm spacer.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Feb 12 2008
    Denver, Co
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    Ok, how here goes some fun for you....
    What I did on my widebody to get my right offset was the following....
    With the car on the ground as it is, take a straight edge that will extend from the floor to above the edge of your fender. Then use a tape measure and measure outwards from your hub (where the wheel bolts to the car, that exact surface and do so with the wheel on). Do this with two people maybe to get an exact result, and double check all 4 corners, both fronts should be pretty equal, as well as both rears. This number is crucial down to the 1/16" of an inch, at least it is to me.
    Anyway you'll get a number, take that number and multiply it by 25.4 to convert to mm.
    That number is a factor of your offset. Mainly take the width of the wheel you would like to run, and then divide it in 1/2. if it's a 9.5" wheel it will be 4.75. Convert that to mm by multiplying x 25.4 which would equal 121 rounded up. The centerline of the wheel is then 121mm. Then take the number you got from the measurement and subtract it from 121. Say it's 4.5" you would then get 121 - 114 = 7. That number is your offset. For the wheel to fit to the fender line you would need to run a 7et. To have the wheel sit in futher simply add to that number, for it to sit in 1/4" add 6mm. And so on.
    Also if you liked where the wheels sat with a 20mm spacer, just ask for 1" bigger lips on the wheels. It's close enough.
    Let me know if you need more help than that.
    Feb 12 2008
    Denver, Co
    Quote Originally Posted by tivs31 View Post
    I am going to do this today! Thanks I will let you know how it goes or if I have any problems.
