Results 1 to 7 of 7
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Car back from shop but have a boost issue.
    Well I got the car back and the oil pump has resolved my Tapping issue at start (Thank good) new cam belt is on and so is the SB stage III clutch which feels like stock I have to say.
    The New Scroll K04 Outlaw turbo is in and working, well I know it is but I have a major boost issue in that it will not boost beyond 5.1 psi.
    I know I don’t have a boost leek as my mate clamped off one of the boost pipes coming off my EBC solenoid pipe and when I took her up the road she boosted to 17psi with no issue at all and that was not even under fall load.
    My conclusion is it may be the solenoid or may be a lack of power getting to the solenoid; I will have another look tomorrow to try and work it out.
    One thing I will say is that the car feels so smooth now. Oh if someone can post me a diagram how the solenoid part connects to the Turbo I would be grateful has I have forgotten the configuration.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Nov 15 2007
    Audi A4
    Redding, California
    Re: Car back from shop but have a boost issue.
    possibly a wastegate issue?
    UK London
    hum wastegate what makes you think that?
    UK London
    Car fixed aaaaaaaaaaaaaaaaaaaaaaaaand
    WOW
    Problem was a broken wire going to the solenoid quick repair quick run up the road and 17psi is easy thing pulls by 2000rpm and by 2500rpm I'm getting full boost (well within 200 yards).
    I have a car to VAGCOM later to clear an airbag light so I will get a better run then but now I'm getting torque steer which I have never had with this car.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    What was the tapping on startup about? I have a tapping sound a few seconds after a cold start and it lasts for like a minute or 2 then goes away. Similar? I have normal oil pressure btw.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    UK London
    Quote Originally Posted by nebone22 View Post
    I used to get it that bad but I did the diesel flush thing which helped a lot and it would only last about 30 sec worse but it was still there. So I had the pump and oil pickup pipe replaced and now its sweet, my mate cause it a lazy pump probably caused by the pickup pipe being blocked making the pump work overtime.
    UK London
    I need to control this boost, thing was hitting 24psi last night when I went for a drive and at one point the car did not like it and would hesitate giving me boost, sort of feels like the EBC is fighting with the turbo.
    I have no idea who said K03s and K04-15 where so similar in power it was not worth doing but this Outlaw K04 is way different as I had no issues with too much boost before now it's just mad and pulls so hard. God knows what going to happen once I get it mapped with larger injectors, Exhaust and MAF.
