Results 1 to 14 of 14
    Sep 27 2006
    CA
    How many of you run wider tires in the front?
    I've tried searching and haven't really been able to track down too much info. People are either trying to run staggered diameter tires, or wider tires in the rear. I don't want to do either of those things.
    Pictures and other info would be great
    Veteran Member Four Rings MAlby7's Avatar
    2017 Infiniti Q50S (HIS), 2014 Nissan Rogue (Hers)
    Woodbridge
    Re: How many of you run wider tires in the front?
    No one will run wider tires in the front. Firstly it looks stupid. Secondly, most audi's are quattro so there's no need to have that FWD drag car look.
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    i can see where he is coming from though. On a circuit having a larger surface area in the front 'should' allow the front tires to hold it's line easier. but yes, a rake stance looks a bit strange
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    You can't run wider tires in the front because of quatrro unless it's something like 255 35 18 front and 225 40 18 rear but that would look hella stupid. Running wider tires will blow your diff, not right away but in the longer run. To run staggered wheel look you have to have the wheel diameter as close as you can to be safe.
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    Quote Originally Posted by GetAwayFromMe View Post
    Yep that's the tire sizes I have on except wider in the rear. I haven't noticed any problems or negative performance.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Depending on what setup you went with, you could end up creating more understeer/oversteer.
    Stage 3+ RS6's
    Jul 06 2005
    Quote Originally Posted by MAlby7 View Post
    No one?
    I know of a few people who would disagree with you there. I know of cars that have even come from the factory that way.
    I'd be willing to bet it would make the car more enjoyable to drive at the limit. It probably doesn't have much use on a street car though.
    Slow, stock, smurfy blue car.
    Relax, I just troll this place for fun.
    Sep 27 2006
    CA
    Why on earth would anyone run wider rear tires (in an audi)?
    That seems pretty dumb to me. Wouldn't this aggravate the car's tendency to understeer?
    I was under the impression that wider/narrower tires wouldn't affect the diff too much if you matched the height well.
    And it's definitely not so I can look "cool," my reasoning was to try and lower the tendency to understeer.
    Sep 27 2006
    CA
    hah malby. way to miss the point
    Jul 06 2005
    Quote Originally Posted by NogaroSB View Post
    You're 100% correct.
    You're on the wrong forum though if you want to discuss function over form.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    You are right, but as Shomegrown said most people here (especially in the wheel department) choose form over function. That is why you see cars with wider rears and not fronts. Wider rears is just for that staggered rwd look that is pointless on these cars unless you are modifying it for drag racing and run actual slicks in the rear. It would just make for a cool looking S4 that understeers even more than stock, if that is even possible.
    Larger fronts would make sense from an handling perspective. You would have to keep the diameters of the tires as close as possible to not mess up the awd. Plus you would at least have to roll the front fenders to make the wider fronts fit as well. A 255/35/18 and 225/40/18 would have a difference in diameter of only 1.53mm, which should cause any problems with the awd system. If you plan on doing some track time I bet it would help hustling these nose heavy pigs around the turns.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    Can you say ricer?
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Hoppen built some fast (for their day) S2 coupe quattros with fatter front tires. They reportedly handled very well, and it was a valid way of reducing understeer.
    "Obsessed" is a word that the lazy use to describe the committed.
    Jul 06 2005
    Quote Originally Posted by nateS4 View Post
    Can you say ricer?
    Actually improving performance at the sacrifice of appearance is the polar opposite of rice.
    YMMV.
    I guess race teams with nose-heavy cars must have it all wrong by putting the wider tires up front.
