Page 1 of 9 123 ... LastLast
Results 1 to 40 of 324
    Feb 17 2005
    Sarasota, FL
    REVO 550cc GTRS File Owners ... Please Read!!
    Has anyone with a 550cc GTRS file tried to run over 23-24psi of boost? Trying to figure out some stuff for myself as well as Chris @ REVO, think I found my boost problem.
    John (Condo) if you read this, did you ever run over 23-24psi before your motor busted?
    Thanks!!
    Shawn
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: REVO 550cc GTRS File Owners ... Please Read!!
    I do all of the time 2002 F Box
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    At sea level I could run up to 28psi (at night) depending on what my ebc was set at... (never over 85 duty on ebc)
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by CO AVANT View Post
    Hmm and never had an A/F problem?
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by 400HPA4 View Post
    You still got the old schoool 440 file fool
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Im confused first off. Boost problem? Thought you had a running lean problem? Then 550cc GTRS file? I thought you were running a GT30 file?
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by A4 TSCHUSS View Post
    Exactly what Im trying to find out, is there REALLY a GT30 file?
    Feb 17 2005
    Sarasota, FL
    And cant run over 23-24psi because of A/F, boost = A/F problem
    Feb 12 2004
    Everywhere
    Quote Originally Posted by A4ringedONE8T View Post
    Sometimes I was, sometimes I wasn't.... just depended on that magical pull in low temps. I was hitting 24-25psi up here today so that is prolly 27-28psi at sea level in the same 60deg conditions... When I ran lean in the 60deg temps on race gas I was only running 25psi.
    Apr 24 2005
    E55 AMG, CTS-V
    what injectors are you running Shawn? 550 or 630?
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Its no surprise to me that you're going lean over 24psi. Your stock fuel pump can't keep up. That is a ton of fuel you're requesting.
    Even Jordan was going lean down near sea level.
    -Doug
    Feb 12 2004
    Everywhere
    No
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Doug, how is your 040 holding up?
    Feb 17 2005
    Sarasota, FL
    I ran 28psi before on the 430 GTRS file and never EVER had a lean problem
    Feb 17 2005
    Sarasota, FL
    Siemens 630's
    Feb 17 2005
    Sarasota, FL
    No
    I agree, Greg confirms, glad I get different answers from different people at REVO, even being a dealer!
    Oct 29 2005
    10speed
    San Francisco, CA
    Shawn Ill throw u a party when you finally realize how crappy revo is
    - Clint
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Thanks!!
    Shawn
    I usually kept it around 23-24psi but I think I had it up to 26psi a few times.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    If thats the case, then there is a significant price difference, right?
    (Isnt the GT30 file ~$1000 and the GTRS/BT file ~$700)
    -Sami-
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    The GT30 file was a $200 upgrade for me from the BT file.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Quote Originally Posted by Condo View Post
    What boost and timing would that be with the revo select?
    Apr 24 2005
    E55 AMG, CTS-V
    No it is $699 for the Big turbo file or it is $100 upgrade if you already have Revo, unless you order it from Eurocode then you will pay $200 for the upgrade.
    ~David~
    CTS-V 9.6@148
    Feb 19 2007
    Charleston, SC
    Whether its $100 extra or $200 extra or whatever.....its still a waste of money? Im just going by what was said in this thread, lol
    -Sami-
    Feb 17 2005
    Sarasota, FL
    $699 for the Elim file, $799 for the 30 series files from REVO (FSI files that I am 100% positive about there exsistance)
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by FourRings80 View Post
    If your using an SPS to control boost, this topic is of no relevance. If your trying to make power, SPS/Select is on B9 and your running an EBC. N75 sures the hell isnt going to cut it
    Apr 24 2005
    E55 AMG, CTS-V
    A waste if you already have the 550cc file I guess, but not if you are on the 440/430cc file
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Or if you're poor like me, mbc
    ~David~
    CTS-V 9.6@148
    Oct 29 2005
    10speed
    San Francisco, CA
    Shawn, can David get the Gt30 file? like is there a file for his ECU?
    - Clint
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    Thanks!!
    Shawn
    What do you think is the problem? You know, you can help put your mind at ease by adding primary fuel in lemminwinks. Bump it up 10% and see if it has any effects on your a/f ratio. If not, the pump is probably your limiting factor. IIRC, your current file requests sufficient fuel, but the actual can't keep up, right? On another note, has anyone ever tried fitting a b5 s4 fuel pump in the tank? Those seem to support up to 450whp on S4s, and are cheap. Figured it'd be worth a shot.
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
    Apr 24 2005
    E55 AMG, CTS-V
    I have 2003 which is 518 AF ecu code and Eurocode flashed my ecu the 2nd time I got it flashed with the GTRS file (supposibly had some little updates) with a 518 BC file which is 2005.
    ~David~
    CTS-V 9.6@148
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The GT30 file is still in the infancy stages and it is not likley you will find the file on the REVO servers.
    In order for REVO to write a file that will work with many setups, first somebody needs to actually get their car running.
    There are quite a few prospects right now but they have not gotten over the hump.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    No complaints. Works like a champ. Thanks again. The Avant is in NJ getting tuned right now.
    Since you 'claim' those are two different files then the fueling in the file you have now is probably not the same as the previous file. REVO can answer whether or not the fueling in the two different file is different. I still think your fuel pump is your limiting factor right now, but that is my opinion and you can do whatever you want with it. The rest of your hardware is there to make the power. You just need to get your fueling and software in check.
    -Doug
    Feb 17 2005
    Sarasota, FL
    REVO does NOT have a GT30 file period. REVO, Ecode, god himself ... nope
    It is on Nick's agenda to visit Ecode once John's car is 100% and make a 30 series file FOR HIS CAR, and his car only, strictly because of hardware reasons. Until then, it doesnt exsist
    Feb 17 2005
    Sarasota, FL
    Wrong, just as I suspected. Reflashed the GTRS 430 file for 518AK before I left the shop, idle A/F is actually BETTER, 10.7-10.8 (10.1-10.3 prior), lamda still at -25%, went up to 27psi, A/F perfect for that boost at 11.6-11.7
    I talked with Chris many times today, he said that if Nick were to make a different fueling file, he would start from scratch, so everything for the file would be different
    Ill add some short logs later tonight, gotta make dinner first
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Silence View Post
    See above
    Mar 19 2004
    Vegas
    Hmm. Odd. Maybe the A4 uses the pump from the b5 s4 after all. Now I am actually curious if the pump number corresponds with a different model car.
    Your idle is that rich? 10.8? Geez. WTF is with that?
    Cheers! David
    Mar 19 2004
    Vegas
    Btw, can you do a full 3rd gear log? Most of yours I've notcied get cut off before 7k
    Cheers! David
    Feb 17 2005
    Sarasota, FL
    Well, 630's on a 440 file with lamda correction at -25% would justify a 10.8 ..... 630's on a 550 file with lamda correction still at -25% and idle A/F at 10.3, who knows
    Obviously the fuel map for the 550 file stops between 23-24psi, hence the reason theres no fuel there. Who knows what else is F'd up in the map
    Feb 17 2005
    Sarasota, FL
    I did a few on the highway coming home but none go past 6k, traffic was busy, and I was still nervous as hell seeing the EBC pass 24psi knowing what the A/F was previously doing. I will do some more logs in the morning to 7k
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Yes there is and it uses 630cc injectors. I sold that setup to JoJo for his GT3071r. Condo has the same file.
    But on what turbo? Because 28psi on a Elim isn't the same as a GT3071r and neither of those are the same as 28psi on a GT3076r.
    GT30 Revo file from Eurocode is $899 if bought alone, $699 when bought along with 630cc injectors. $200 upgrade for Revo BT file owners that can prove they bought it brand new.
