Results 1 to 19 of 19
    Senior Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A6 c6 3.0 Tdi (300hp)
    Ukraine, Kiev
    2.0 TFSI do I nead a test pipe?
    I have chiped A 4(250 hp) with cat back. I was told that when I will del cat I will lose torgue in low rpm. Is that true? Should I keep cat?
    A6c6 3.0 tdi(300hp), koni sport shocks, eibach pro kit springs, q5 4pot brake calliper, a8d3 sport seats
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Re: 2.0 TFSI do I nead a test pipe?
    no, you won't lose trq. if you do, it will be a few lb/ft, and you'll gain more up top. you will need a software file that deletes the code though or you will have a constant CEL
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    if you get a testpipe you'll gain more hp and torque, not lose.
    Veteran Member Four Rings dreamcar=rs4's Avatar
    Nov 04 2007
    A4 2.0T
    NorCal
    Quote Originally Posted by Johnnie View Post
    You'll lose torque in the lower RPMs because of the lack of back pressure.
    Dec 27 2005
    Ft lauderdale
    oh was that what he was talking about? well overall you'll gain like AAAA said so i say do it esp if you're concerned about power.
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    3inch testpipe equals perfect tone for the 20T if everything else flows :P
    Jul 21 2004
    South Florida
    You will GAIN torque, not lose it. Look at eurocodetuning.com website for their before and after dyno of their testpipe on the stock car. The biggest gains were down low. Keep in mind, on a fully chipped car (one running a 93 octane agressive program) any gains are going to be much more minimal because of the fuel limitations.
    cheers! Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    As previously stated above, you will gain a significant amount of torque, and spool up of the turbo is going to be significantly faster.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    the only drawback i see is that you won't be able to pass emissions tests. Im not sure how it works in europe but in the US it is illegal to run a TP on the street
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by a4dc89 View Post
    There is no problem with that in Ukraine
    Quote Originally Posted by bhvrdr View Post
    cheers! Mike
    What size of DP should I use 3 inch(eurocode propose 2,75)?
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    Quote Originally Posted by 06B7audiA4 View Post
    that may be true but 2.5" is better than 3". if you go 3" you will most likely be loosing more low end torque and possibly end up with turbo problems later on. go for VMR's my buddy just put his on (only 69$) and it sounds / works great
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    I'm seriously considering getting the VMR TP. It's only $69 shipped and you can't beat that. It's a great deal for a great product. I've only heard great things about it.
    Jul 21 2004
    South Florida
    Quote Originally Posted by DOBERMAN@UA View Post
    At these power levels either one is fine. Again, i really wouldnt worry about losing torque on a turbo car that spools by 2500rpm and I dont think youll "need" a 3" setup until well into BT territory but I dont see it would hurt either. Go with whatever you want. If one or the other mates up to the rest of your exhaust with a smoother transition i'd go with that one. Some folks have 2.5" downpipes, some 3" so maybe look at that and pick the one for you.
    cheers! Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    here we go again. another test pipe thread. -_-
    http://www.audizine.com/forum/showthread.php?t=185926
    DUH! an Audi
    los angeles, CA
    HFC (High Flow Cat) FTW!!!!!
    love mine
    Apr 15 2007
    WNC
    how much is an HFC?
    2013 RS5, 2014 Q7
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by rnp614 View Post
    how much is an HFC?
    About 1000 from Miltec, but test pipe about 200
    Apr 15 2007
    WNC
    How much difference is there in gains? What if you dont change exhaust from stock?
    2013 RS5, 2014 Q7
    Sep 15 2008
    Ukraine, Kiev
    Difference is about 5 hp(in test pipe bigger). Good exhauste worth of money! you will hear engine enough I have central part from Super Sprint and rear muffler from ABT, sounds great
