Ok, so I finally found where my Coolant temperature sensor is
for those that dont know and have a 2.8 A4 ( 99 )
You have to remove the intake piping from the throttle body and you should see a plug with 4 wires on it. Chances are its going to be blue in color.
Also, im going to tackle this mis fire on cylinder 2 CEL i have.
Hopefully its just the spark plug ( I hope )
Next would be my other o2 sensor.
Recently got a code for B1 S2. Didnt realize I also had code for B2 S2.
on another note: Does you coolant temperature sensor have any effect on the AC?
I notice my AC doesnt come out as cold as it used to. When the coolant sensor does work and needle raises it feels like the Ac comes out colder.
Any chance those two things work together?
