1999 a4 quattro 1.8t
just got my new motor all built, got it running right for last 400 miles, smile from ear to ear after this build...driving it today and the boost seemed to cut out at anything over about 4 k depending on gear, thought it was a boost leak. So i let it cool down watched football at my buddies, on the way home i let it warm up to operating temp, and the car pulled fine, did a few pulls through each gear, everything ok. Drove casual for a while, then tried another pull and felt like the same thing, like the boost cuts out.
The part where the car drove right kinda rules out the boost leak.
also there is no cel, and the car idles great and drives great till a certain point of boost seems like.
was searching and i know my abs module is bad cause vag won't let me communicate to it and my abs light stays on and the brake light flashes. last weekend i did both rear wheel bearing and cut the abs sensor wires to the hubs, cause they wear stuck in the holes.
could the abs module/ cut sensor wires have anything to do with the boost cut/throttle cut?
or let me know what you think.
