Results 1 to 10 of 10
Thread: oH Shift
    oH Shift
    Little Help here, How do you remove the metal ring that is holding the shifter nob on. It is accessable under the shift boot... The goal is to remove the shift boot
    KO
    EcoLuxuryDetail.com
    6-Speed, Neuspeed Chip, Heat Shield, 034 Intake, Euro Jet PCV, 3" Magnaflow, Test pipe, Sport Suspension, RS4 Sway, Snub mount, Apexi super ground, K&N, RS4 Pedals, Podi, Hawk HPS, Super Blue Fluid, Chrome Mirrors, Clear cornered, Laminx, Debadged, Ziza Led, Xexon Interior, Alcantara boot, Infinity 1000W 12", painted markers, VAG's 19" A8 12 Spoke, 10 & 15mm Spacers
    DUH! an Audi
    los angeles, CA
    Re: oH Shift
    ummmm, you mean to remove knob??
    if so, you get that metal ring, turn left then you pull the button out a bit and pull up...
    not sure what you mean by shift boot as b7 a4s dont have them, from what I know
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    Re: oH Shift
    you'll probably need to cut it off and just use a ring with a screw in it to tighten it, if you want to put it back.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Feb 10 2004
    2009 A4 2.0T Sedan
    Re: oH Shift
    Yup, cut it off or use a flathead screwdriver to loosen it. Either way it'll be unusable afterwards, which is when a zip-tie can come in handy.
    Re: oH Shift
    Ok I will cut it up! I will make sure to post a full write up with lots of pictures...lol
    Thanks! KO
    EcoLuxuryDetail.com
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    Re: oH Shift
    Quote Originally Posted by Quattro View Post
    You must have tip, becuase B7 A4's have shift boots.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Re: oH Shift
    yea the one time clip is kinda a pain....just break it apart and then you can just pull up on the boot. Get a 1in clamp so when you put the boot back on you can make sure your knob wont move on you.
    Feb 10 2004
    2009 A4 2.0T Sedan
    Re: oH Shift
    Quote Originally Posted by vtracer20 View Post
    Yes that would be a bit less ghetto than the zip-tie method. Either way, you definitely don't want the shift knob slipping off while driving.
    Re: oH Shift
    It is 6 Speed & I was able to take a vice grip squeze & twist & it poped off. Now how the hell do you remove the shift nob from the boot??? This can be this hard... lol
    KO
    EcoLuxuryDetail.com
    Feb 10 2004
    2009 A4 2.0T Sedan
    Re: oH Shift
    Quote Originally Posted by Cosworth View Post
    KO
    You don't, it's all one piece. It went this way starting with the B6, as on the B5 it was two separate pieces.
