Results 1 to 10 of 10
    Registered Member Two Rings TheBigO's Avatar
    Apr 13 2008
    '05 B6 A4 SE 1.8t CVT
    Atlanta, GA
    Good prices for USP front, read, and sides
    I'm starting to shop around for my upgrades.
    I'm thinking of putting on USP front and rear bumper, and side skirts.
    What are the types of pricing I can expect?
    So far I've found:
    USP Front: 396.90
    USP Rear: 354.63
    USP Sides: 472.50
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Re: Good prices for USP front, read, and sides
    i wouldnt pay that much for my sides
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by TheBigO View Post
    So far I've found:
    USP Front: 396.90
    USP Rear: 354.63
    USP Sides: 472.50
    USP side skirts are the same as stock.
    Apr 13 2008
    Atlanta, GA
    Quote Originally Posted by Condo View Post
    Gotcha. Makes things much cheaper.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    side skirts are the same but door blades are not. perhaps that is what you meant by "sides".
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Dec 19 2007
    York, PA
    didnt someone just post up that they got the usp front and side grills at cost for $25x.xx?
    May 22 2007
    oakland ca
    from what I have found, front side grills (small) are 35 - 40 each. The center is the big expense at around 150 - 165
    Dec 19 2007
    York, PA
    ^correct
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    To do the USP front, you can add on the lower lip and grills to your existing front bumper, typical cost for the lower spoiler is $190.00, the center grill $165.00 and the forglight grills $35.00 each, you can do the USP door blades for about $425.00 or the S4 for $380.00
    The USP rear bumper is a whole different story however, it is a two piece bumper and the only thing you can reuse from your standard bumper is the aluminum trim strip.
    Like the front end however, there is a DIY workaround for the bumper support. The cost for the rear upper and lower bumper is about $900.00
    I have sold the entire USP assembly in the past and with shipping, everything came to about $2,200
    Apr 13 2008
    Atlanta, GA
    I appreciate the feedback.
