Results 1 to 7 of 7
    2003 A4 1.8TQM
    Markham, Ontario
    B6 A4 Brake upgrade - will this work?
    Depending on the source, there is or is not a 1mm difference in diameter between the B5 S4 and B7 A4 front rotors - 321mm B5 S4, 320mm B7 A4, both 30mm wide.
    Is this difference enough to make the caliper / carrier choice critical?
    Reason I'm asking is that my potential brake upgrade would be B5 S4 rotors (321mm x 30) and B7 A4 calipers / carriers - primarily because the B5 S4 rotors seem to be available for less $$$.
    But will this work?
    Anyone?
    TIA
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: B6 A4 Brake upgrade - will this work?
    Quote Originally Posted by Roadie73 View Post
    But will this work?
    Anyone?
    TIA
    That setup will work just fine.
    Established Member Two Rings nyconickk's Avatar
    Jan 30 2006
    area 51
    why don't you just go with the b5 s4 calipers??.. aren't they dual piston?
    life goes by to fast to put things off for tomorrow, so boost all you can when u can
    Nov 09 2006
    08 cooper S, 97 C4S, 95 C4
    Tacoma, WA
    Not sure on the sizes, but you should be ok.
    Now, I would also highly suggest you do the rears as well. Audi's are really heavy front braked. One you make the fronts even more so, you are putting way to much front bias on it. This can have negative affects, like taking much longer to stop! Do the rears as well, with either the B5 S4 kit, or something like the Stasis rear kit.
    2003 A4 1.8TQM
    Markham, Ontario
    Current plan is:
    Frts - B7 A4 calipers / carriers, B7 A4 frt rotors from Adam's group buy, Hawk HPS pads
    Rear - Stock calipers / carriers, B6 A4 rr rotors (Adam's) Hawk HPS.
    I figure the BI flash at the same time should ensure the car remains balamced
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Too much front bias you say. I disagree my stock A4 brakes didnt stop for shit then I upgraded to S4 front calipers and it stops on a dime. I had to ease into the brake the first few days of driving else I would snap my neck lol.
    Quote Originally Posted by Mike@Startup View Post
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    why not try to get a Stoptech Caliper?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
