Results 1 to 30 of 30
    Aug 06 2008
    Canadia
    what do you set your tire pressure to?
    I'm running stock wheels/tire size and i decided to bump things up 2psi front and rear, so now i'm at 38psi front and 36 in the rear, so far so good.
    just wondering what everyone else is running and how they like it.
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Re: what do you set your tire pressure to?
    32 in the front and 34 in the rear to reduce the understeer.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Senior Member Three Rings SilverThing's Avatar
    Dec 26 2007
    cars & stuff
    Long Island, NY
    Quote Originally Posted by jcanni View Post
    ^^^ x2 - works for me
    Rides:
    '06 S4 Avant, silver/black w/ alcantara, w/ V8 goodness - new DD (finally back in an S!)
    '07 A4 Avant 2.0TQ S-line & Ti, I-white/black (unicorn?) - w/ APR goodness, old DD, now beach-mobile
    '93 BMW 850ci, FE Red/Black - major garage queen
    Previous:
    '01.5 S4 Avant, Silver/Onyx (Sold...miss it a whole lot )
    '98 BMW 328ic, Cosmos/Grey/Black (Sold...miss this one a whole lot, too)
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    41 and 40 my 235 18's they stick like glue still F1's but on stock rubber i run 34/36 ( winter mode)
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    40 front and 42 rear.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    just topped 'em off yesterday at 40psi front and 38psi rear (235/40/18)... gas is too expensive to be running 34/32
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    40 all around.
    Account Terminated Two Rings
    Jul 29 2008
    New York
    35psi all around
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    38f 40r Toyo T1R 225/18 on CHs
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    36psi front 38psi rear 245/35/19 FK 452's... Works good so far.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    40/40
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    40F/38R on 225/40/18 or 38F/36R on stock 225/45/17
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Quote Originally Posted by Quattrocket View Post
    40/40
    +1
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Aug 06 2008
    Canadia
    looks like half the people set the rear higher and half the front higher, some the same.
    I used to set the rear higher because some website said it reduces understeer, which it seemed to do until i went auto crossing one day and i discovered all that did was make my front tires roll over onto the sidewalls.
    I find setting the rear higher helps turn in response, but not much else. considering how light the rear is on a S4 (and that i don't have traction control), i'm going to leave the rear a little flat so i can a bigger contact patch.
    thoughts?
    Mar 08 2007
    Mr. Worl-Wye
    ^^yeah, I was gonna ask the same thing: how come all of you guys are running less tire pressure up front where there is more weight/load??? I had heard something similar re: tire pressures for a track set-up, but I'm not sure if it applied to awd cars or not. I'm also willing to bet that 99.9% of people here don't track their cars so it seems kinda pointless to me...
    Quote Originally Posted by Kruat View Post
    Quote Originally Posted by Evilevo View Post
    Quote Originally Posted by Dimcorner View Post
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Sep 27 2007
    Columbia, SC
    I haven't tracked this car, but I have the Mazda3 and the rear pressure helped A LOT (and yes, all the weight is REALLY in the front of this car).
    I don't know how increasing the rear tire pressures make your front tires roll. Could it be that since the back is now sliding more you are slowing down (braking, engine braking) and transferring more of the weight up front?
    On the Mazda I run 38 front 42 rear (warm).
    Tires were the OEM RS-A's. Anything less than 35 and they feel sloppy.
    On the Audi I have Nitto NeoGen. I haven't tracked it yet but I probably won't track these tires. The side wall is way softer because they are all-season tires. If I had stiffer sidewalls the pressure might change depending on how the car feels. Right now I have pretty neutral steering. Tail doesn't slide out, but it won't exactly plow either.
    If you put more pressure up front the side walls stiffen and the contact patch get's smaller so the front would slide more. Also remember that a good chunk of the engine sits in front the the axle. So you have all the weight up front, smaller contact patch, and now you are asking the tires to pull the car sideways. The rear tires help a little, but only in going straight so no help turning, they are just along for the ride. If you are accelerating through a turn, this will transfer more weight to the back and the patch up front gets smaller. I always brake later (or engine brake) and use the throttle to help me turn the car. Not much, just small adjustments.
    I think in the end it depends on your driving style and how you plan to use the car. Just remember that it changes every time. Different tire brands, road conditions, temp of the day, etc. You really can't use one set setup every time. You can start with it, and then make adjustments from there.
    Personally I keep them high and I have been getting almost 23mpg combined here in Miami :(. Up when I was in Raleigh I was hitting 28mpg combined. This is using 40+psi on the tires.
    96 Soarer GT - Gone
    Veteran Member Three Rings rouellettea4's Avatar
    Apr 07 2005
    00S4STG3, 1995 Subaru Impreza, 96 A6 (blown HG)
    Holden/Worcester, MA
    Hmmm, I usually run mine 34/34 on my oem wheels 225 tires. I guess I can be running a bit more pressure huh. Always was curious here.
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    X2^^
    Sep 27 2007
    Columbia, SC
    Quote Originally Posted by rouellettea4 View Post
    Make sure you are under the max rating for the tire when it's warm.
    42psi cold is not the same once you start driving so keep some overhead just in case.
    96 Soarer GT - Gone
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    Quote Originally Posted by MacDaddy View Post
    thoughts?
    You are right on this one... I track my car at least 4-5 times a year and have tried tons of different settings. I have come to the conclusion that our cars handle way better buy running more pressure up front. Right now I went for a drastic setup and it's working very well (front set at 36psi cold, rear set at 31psi cold). I know this looks insane, but for those of you who try it, I think you will come to like it....
    Senior Member Three Rings Bee Five's Avatar
    Jun 06 2008
    Northern California
    Quote Originally Posted by VR4-S4 View Post
    +1
    x2
    I run 40f/40r psi on all my cars, best combo for fuel economy and even tire wear
    /_/// 2000 S4 // Alcantara // Light Silver Metallic // Sport Package // 6-Speed
    APR Bi-Pipe // APR ECU // Fikse Mach V Wheels // Forged DV // JHM SS // Piggie Pipes
    ECS Stage4 BBK // RS4 Grill // SRP Pedals // ST Coilovers // UUC VM2 Exhaust // UUC Knob
    Aug 06 2008
    Canadia
    I wasn't meaning that increasing the rear tire pressure increased front tire roll (thats how it sounded, i know). what i meant is not inflating the front tires really high allows them to roll over onto their sidewalls, i could have been more clear there, my bad.
    anyway,
    despite the fact higher front tire pressure moves the contact patch more to the center of the tire, my grip is far better in a corner as the contact patch shifts from the side and middle of the tire instead of entirely to the side/sidewall.
    next time you track your car, try setting the front higher and you'll probably have to set the rear proportionately lower to balance things out. what your looking for is the little arrow on the side of the tire pointing outwards to the tread, you don't want to see any tire wear above or below the tip of that arrow. Once you get it in that sweet spot up front, experiment with the rear tires to find what works best.
    Sep 27 2007
    Columbia, SC
    anyway,
    I wouldn't be surprised if this is the case. Every car is different and every tire will act different too. Once I get the turbo's done I'll probably hit up a AutoX and test out pressures.
    96 Soarer GT - Gone
    Mar 08 2007
    Mr. Worl-Wye
    This is some good dialog guys! I can see that running even more pressure up front than the rear (greater delta) for a track setting might be very complementary to our car's natural short comings. I'm def. gonna try it when I hit the track soon (*knocks on wood*).
    But during the week and around town, you should probably run F&R a little closer to one another, with no more than 38F/36R cold IMO. Since there is a more weight up front and less in the back, running reverse pressures (i.e. 36F/38R, or worse) is sure to wear the tires unevenly: the fronts will wear more towards the outside edges, leaving the center "unused"; and the rears will wear out the center, leaving the edges unused. Now combine that with prolonged unbalancing, tire rotations, and/or alignments and you're bound to get feathering, cupping, or crap that will wear out a tire real fast...
    After installing countless of tires for PepBoys in my youth, and checking/adjusting tires pressures for clueless customers, I can honestly say I've seen it all I will agree it all depends on the tire brand, compound, side wall height & stiffness, climate type, driving habits, etc., etc.. So many variables, but pressure is the most commonly overlooked one.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Mar 08 2007
    Mr. Worl-Wye
    hey man, you mentioned you get 23mpg around Miami? What are do you frequent, cause I'm in Coral Gables... Not sure if you attend any of the meets, but I hardly see any B5's
    Let me know if/when you hit the track next time.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Sep 08 2008
    2K S4+79Merc300SD+65Barracuda
    Rohnert Park CA
    Good thread! 32psi front 34psi rear. (for track) max psi for long distance travel to obtain optimal MPG. I run higher psi in the rear to allow the rear end to slide out. This helps in control for aligning the car in turns. Otherwise it will keep going in the same direction even though you turn the wheel. "Sipped" Toyo Proxes 4
    Registered Member Two Rings vladbe's Avatar
    Jun 16 2004
    2002 Audi S4 casa white
    Washington
    42 psi all around.
    2002 S4 Casablanca White
    2000 540i 6 spd
    Veteran Member Three Rings AUDILUX's Avatar
    Oct 16 2007
    B5 S4 / 335i
    So, some of you are saying front tire pressure should be higher for better handling (due to higher weight load on the front tires) and some of you are saying that rear tire pressure should be higher for improved handling (in order to decrease understeer/create oversteer). Which one is it??
    My Garage: 4 door, AWD, twin-turbo Germans -
    • 2001 Midnight Purple RS4-widebody S4 (ASP Stage3)
    • 2009 Alpine White 335ix sedan
    Speed has never killed anyone, suddenly becoming stationary... That's what gets you. -J. Clarkson
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    lol
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Sep 27 2007
    Columbia, SC
    Quote Originally Posted by BITRBO View Post
    I live up in Pines, but my parents live in Sweetwater right next to FIU so I go down quite often. I tried to go to a meet last time but now one showed up (Tropical park at 2:00pm or so on a Sat.). When is the next meet?
    As for tires...
    I believe that I ran 38 front 36 rear on my RX7 because it was too tail happy (I also set the struts to max on all 4 corners, Yokahama tires). I went back to stock size with BFG KDW's and had to increase rear because the car would now plow.
    Yeah there are a lot of variables. If you are just driving every day and not really trying to get around a track in the shortest time then as long as you are at least the recommended pressure you should be fine. Otherwise you will just have to experiment and get a few runs in.
    96 Soarer GT - Gone
