    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    Which Oil? (2nd Thoughts)
    I've been using pentosin, 5-40 fully synthetic. But because I have about 140K miles on my 30v, should I change it to Castrol Syntec 10-30 now?
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Established Member Two Rings newtonc2001A4V6's Avatar
    Jan 23 2006
    2011 Audi A4 2.0T, 2004 Lexus RX330, 1977 MG-B
    Colorado
    Re: Which Oil? (2nd Thoughts)
    Quote Originally Posted by oldblu View Post
    Why would you want to change? ... the Castrol Syntec 5W40 is an ACEA A3 rated oil that also meets VW 502/505 and the Syntec 10W30 is not.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Boo Castrol.
    Mobil, Motul, ... there's lots of good brands out there to choose from.
    I use Mobil 1 0W-40, when I get the cash I'm buying a big bulk order of Motul I think.
    Jan 01 2008
    Budd Lake, NJ
    Brand doesn't concern me as much as viscosity does. After talking to my uncle who used to be a mechanic, he said that due to the wear on the motor, a thicker oil should be used - 10-30. Should I switch?
    in my lemonade?
    Jan 23 2006
    Colorado
    Castrol Syntec 5W40 - Viscosity @ 100 degrees C = 14.0
    Castrol Syntec 10W30 - Viscosity @ 100 degrees C = 10.1
    So, in other words, at operating temperature, the 5W40 is thicker.
