Results 1 to 24 of 24
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    Ebay Intercooler Piping Kit
    I am looking for a set of DIY intercooler piping kit for my 25"x6.5"x2.5" FMIC. Overall size with end tanks is 31.5"x6.5"x2.5"
    Well i don't mind cutting, just wondering where did you get yours? eBay?
    http://cgi.ebay.com/ebaymotors/2-5-F...spagenameZWDVW
    http://cgi.ebay.com/ebaymotors/CXRac...d=p3911.c0.m14
    What's your suggestion?
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Ebay Intercooler Piping Kit
    A lot of people love the CX racing piping. I have seen their piping it it looks really nice.
    Aiite, thx very much. I will order from them~
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    2.5" is a little big if your only running a ko3 or ko4...
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    2.25" is the size piping you want to run if you're just gonna be KO3 or Ko4
    i am running gt28, what do you guys think is best? 2.25" or 2.5"?
    IG:@steadysupreme
    Pics&Detail
    Nov 15 2007
    Audi A4
    Redding, California
    2.5" for a gt28 for sure
    Nov 02 2007
    2008 S-Line A4
    Denver
    2.5" should work for that then
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Im running a T28 with 2.5". I think that the turbo would spool quicker with 2.25. I also got my piping from CXracing
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Yah, i don't mind getting the turbo to spool quicker too
    Quote Originally Posted by biketsai View Post
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Three Rings jankaroni's Avatar
    Mar 01 2007
    Emerson/NJ/USA
    i am doing the same thing....right now I am just running the K03s but am planning on upgrading to a 2871r elim when this turbo gives up. What size pipe would you suggest in that case?
    FYI it might be a little while before the turbo gives up on me.
    Jun 04 2007
    Austin/DFW, TX
    2.25"
    My 5-Speed Swap DIY
    - B6 USP
    Mar 01 2007
    Emerson/NJ/USA
    so should i get a core that has 2.5 inch ins and out and just get 2.25 inch tubing? I dont want to have to replace the core and everything when i do upgrade if i dont have to.
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    Cold side 2.25 ,hot side 2.50 is the best combo but needs to be done custom :)
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    Mar 01 2007
    Emerson/NJ/USA
    Quote Originally Posted by prodrive View Post
    Awesome thanks for the advice, I noticed a lot of the ebay kits say you need to weld in a flange for some sensor? What exactly do I need to weld in and for what?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    that is for the MAP sensor which only comes in 2000 models and up. if you are AEB engine code, 97-99, you dont have to worry about that.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    i bought a $78 2.5" ebay kit. had more than enough pipe and couplers. just needed to get a map sensor flange (ebay-$20 shipped) and a 2-2.5" reducer to go from the pipe to turbo outlet. works great so far. just make sure you get t-bolt clamps if the it comes w/ the shitty ass worm gear ones.. they will hold all of about 5psi... if u'r lucky...
    <--------yes, i used my audi to drag my deer out of the woods. it was heavy, i was cold, car had heat, much less work, and frankly, it was far. the deer was big, i am not, just seemed like the right thing to do. if it werent for the apr2+ i may not have been able to pull that monstrosity out of the woods w/out a helicoptor. i cant afford a helicoptor, i have a hard enough time affording my audi. all this being said, yes. that is an apr2+ awd audi pulling a deer out of the woods.
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    Be carefull when buying from ebay becouse there are two types of piping ,some sellers offer 1.5 mm thickness piping which is cheap and the others 2mm. It's better to buy 2mm piping if you gonna make welding job.
    Feedback: Clicky
    Mar 01 2007
    Emerson/NJ/USA
    I am looking at this kit here.... http://cgi.ebay.com/ebaymotors/FRONT...QQcmdZViewItem
    I dont see any listing of what size the piping is, but it comes with the map sensor flange it just needs to be welded in which I can take care of.
    How much of a difference would it make if the whole thing were done in 2.5 rather than 2.25? Would it just increase the turbo lag?
    Feb 28 2007
    04 a4 USP ; ATS
    Do whatever size you want but 2.5" is completely unnecessary and will just hurt the setup, not literally.. Just as far as lag/psi goes. 2.5" piping is what should be used on a larger turbo IE:3071 ect..
    Oct 06 2004
    Minnesota
    Quote Originally Posted by jankaroni View Post
    Yes you will have turbo lag because it is more volume that needs to be compressed.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Feb 07 2008
    just the a4
    northeast pa
    i use 2.5" w/ my k03... only noticeable dif is the increase in power from the fmic. no noticeable in lag or spool time.. might be worth a tenth at the strip, but nothing to worry about
    Mar 01 2007
    Emerson/NJ/USA
    Yeah i am just going to go with the 2.25 as it appears from the responses that there is no need for 2.5 and if anything it would hurt the performance some. I can get everything, piping and the intercooler on ebay from Just-Intercoolers for like 200 bucks.
    Apr 22 2007
    2010 Audi A3 2.0T Quattro Prem+
    Boston, Mass
    I was actually in the market for a FMIC and found this post in ebay.
    http://cgi.ebay.com/ebaymotors/CXRac...spagenameZWD1V
    It's a Cxracing FMIC that I've been reading around the forum here. I made him an offer for $150 + $47 shipping. It pretty much equals out to $197. Which is what you are looking for. He gladly took my offer and bought I it that night.
    To me it looks like it's good quality and if at all, close to the Godspeed core. I'll try to post up my setup once I get this thing and find time to install it.
    2010 A3 2.0t Quattro - APR Stg 1, Dog Bone insert (not yet installed), 40% Tint (no plans to get pulled over), Dension GW33AC1 w\ SAT PASS 3
    1998 A4 1.8t Quattro - Sold!
