Results 1 to 10 of 10
    Oct 22 2006
    Will removing my SAI system hurt my engine?
    hey boys i seen this 1.8t SAI Blockoff Plate from http://www.intengineering.com/Shop/C...id/0/SFV/32093
    and was just seeing wat affects will this have on my engine other than freeing up room?
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Will removing my SAI system hurt my engine?
    give you a CEL for it not working and wont pass inspection with it missing, atleast here in the us its like that. wont hurt the engine though
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    the SAI system works when you first start up the car. It puts more oxygen into the exhaust system so the catalyst will "light off" or come up to temp more quickly. Removing the SAI system will not damage anything. It will turn on your check engine light as it will not see proper SAI flow.
    Some of the tuning companies offer SAI delete files with their flash tunes.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    The B5 doesnt have SAI does it . I have a AEB head for my B6 and there is no SAI port on the back of the head where the block off plate would go like on the B6. And no it doesnt hurt anything to take it off, it is just emissions crap.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Feb 28 2007
    04 a4 USP ; ATS
    The SAI started on 2000 models (ATW) the aeb models dont have SAI.
    Oct 22 2006
    Quote Originally Posted by njm23 View Post
    so how does aeb engine pass?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I removed mine, now i have alot of space =] haha. It shoudlnt harm anything, and I get the code for it every once and a while
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 28 2007
    04 a4 USP ; ATS
    the aeb doesnt require the SAI, they made the car to pass emissions without it.. the 2000 needs the SAI to pass emissions
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    If SAI is factory installed then you must have it to pass E-Checks. AEB's were able to pass with out, whether or not the standards changed in that time I don't know.
    AEB's FTW, we get the good head.
    Senior Member Two Rings bmx_a4's Avatar
    Aug 19 2008
    Sheridan, WY
    No emissions testing here in Wyoming. :P I win.
    2006 Jetta TDI
    2000 Brilliant Black S4
