Results 1 to 4 of 4
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    where to get mounting hardware for warning triangle
    I have the warning triangle from a b6, and went in put in my b7 and realized there's nothing to hold it in place. where can i get the mounting brackets and how do i install them?
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: where to get mounting hardware for warning triangle
    I'm sure you can get it at the dealer. maybe check ECS tuning. There are 2 ways to go about mounting it. If you pop your trunk you can see where it goes.
    1. The first way is to remove the trunk lining, with it removed flip it over and you should be able to see where you need to cut to mount the holder. It is very easy to take off, just pull it out and the clips won't break, they are metal! Use a razor and cut, then put the lining back in and put the holder in place.
    2. The second way is to leave the lining where it is and cut into it. I put my hand inside the lining, found the holes where the holder goes and started cutting. then just keep testing with the holder until it snaps into place. Keep cutting till it fits!
    The usual things!!
    Resistor Install
    Dec 27 2005
    Ft lauderdale
    k thanks for all that information. can't find the mounting bracket on ecs... how much is it at the dealership? i'm gonna check oem.pl now.
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    I saw it at one the audi tuning sites in one of the rotating banners here. It came with the triangle and the footer bracket to hold it in place. Can't recall the site off hand however.
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
