Results 1 to 9 of 9
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    Removing the fold down utility (cd changer) door
    Anyone done this or know how to remove that door without ripping it apart? I added a fiberglass sub I made to go behind that door but the door won't close and the sub needs a lot of clearance. I want to either leave the door off, or make a grill that allows more space of the sub. Both options require that door to be removed. However, it looks as if the door is crosss-sectioned with that entire side panel. Has anyone removed theirs damage free where it can be re-installed later?
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Feb 05 2008
    Orlando, FL
    Re: Removing the fold down utility (cd changer) door
    So nobody knows how to remove this door? I was hoping someone knew a trick, otherwise, it's Dremmel time.
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    You mean the interior part ?
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Your cd changer is in your truck?
    Feb 05 2008
    Orlando, FL
    I don't have a CD changer, but there's a tray inside, I assumed it was for a changer.
    It's the right side drop down door inside the trunk. I want to remove just the door from that side panel. It seems to be some type of hinge, but I want to not destroy it if possible. I installed a subwoofer behind that door, but for now I leave the door open, laying down on the floor of the trunk. I'd like to remove the door and fiberglass a mold of it so I can make a pop off grill or just leave the woofer exposed.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    I see, I was confused as well. I was thinking about a speaker in your dash! If you take out the trunk lining on that side you should be able to get it out.
    The usual things!!
    Resistor Install
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    I used a flat head screw driver and slowly pried it off with good results.
    Feb 05 2008
    Orlando, FL
    A screwdriver underneath near the hinge? It looks like it's intertwined. But I'll give that a shot this weekend, thanks.
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    umm if you mean that small retangular box where the satellite receiver goes.. then just put a screwdriver underneath the tabs and pull out. if you want to remove the entire plastic part behind that door... then you have to remove the carpet around it and theres four screws that holds it in place. search of a diy on satellite module install.. theres one floating around somewhere..
