Results 1 to 7 of 7
    Mar 27 2005
    The Cold North
    Samco TIP on the 2004 1.8T, what extra fittings are required?
    I ordered a Samco TIP (samco part #TB1360) only to find out it may not be a perfect fit on the 2004. apparently it works fine on 2001-2003. I was searching but i can only find the issues with the APR tip. I just want to get the extra parts before i start the install.
    What else is needed to fit the Samco tip on the 04?
    thanks
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    Re: Samco TIP on the 2004 1.8T, what extra fittings are required?
    It's just like the APR hose. You just need one t-fitting and three extra clamps and you should be good to go. I went to Home Depot and bought a Brass-t
    4Runner, Rs5 and Alfa Guilia QV
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Similar question for me but I have a 2003 and want to install a Forge TIP. I understand I need to plug one of the holes. But what do i use to plug the extra hole ( no homo intended LOL)
    another stereotypical Audi
    Apr 08 2004
    Eating Cheese Curds
    Hopefully it comes with the required plug. The hole to be plugged is the upper (closest to the MAF.
    Jul 27 2004
    Bay Area 925
    Quote Originally Posted by Groove1797 View Post
    Mine did not come with the plug...got any ideas what i can use? ANyone?
    Jun 08 2008
    Calgary AB Canada
    bolt with some teflon tape?
    Mar 27 2005
    The Cold North
    thanks for the help everyone. I am actually sending it back to place i purchased it. I am going to order the forge tip instead.
    2020 Chevy AEV ZR2
