Results 1 to 6 of 6
Thread: will these fit?
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    will these fit?
    Front wheels 19x8.5, offset ET38
    Rear wheels 19x9.5, offset ET34
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: will these fit?
    depends on how low you are and what tires.
    probably will have to run some negative camber if you are dropped
    -Sami-
    Oct 17 2007
    mass
    Re: will these fit?
    does anyone if these will fit cause i need to know
    May 21 2007
    Florida
    Re: will these fit?
    if you run the right tire size yes they should. thats also assuming they are 5x112, which im sure they are.
    ahh i mean, no they wont. buy my OZ's instead
    2018 Navarro Blue Q5
    Oct 17 2007
    mass
    Re: will these fit?
    nvm nate the bidding just ended on ebay i coud of just got hre's
    May 21 2007
    Florida
    Re: will these fit?
    bmw wheels=wrong bolt pattern
