Results 1 to 9 of 9
    Nov 16 2007
    Westerly//Providence
    question about spacers
    i searched, could not really find the answer i was looking for. if this has been answered before please link me to the thread.
    anyways here is my issue, i recently put 19" enkei's on my car and in order for them to clear the front brakes i needed spacers...i ordered 4mm spacers they clear my brakes fine. for some reason while im driving it seems like i hear the tires//pavement meeting but its too loud for it to be that. i can hear it over my system when its bumping pretty hard. i have eliminated the sound from the rears (no spacers in the rears...yet). is this common for the first few days of spacers or is there something wrong or??
    just a few notes:
    The car has not be re-aligned (doesn't seem like an alignment would be the cause for this noise), tires are balanced, and the tred on the tires is about %60 at the least on Kuhmo's.
    DUH! an Audi
    los angeles, CA
    Re: question about spacers
    search under user name "superman99" or something and put spacers... he started a thread dedicated to spacers, pics etc.
    check to see if you have tightened the screws, seems like that could be your problem...when running spacers that are not hubcentric, sometimes its hard to get the wheel bolts in straight.
    Nov 16 2007
    thanks randy
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    just double check everything for any rubbing, i just put some spacers on my front (10mm) and everything seems fine
    Nov 16 2007
    nothings rubbing...not even lowered yet...i kinda stumbled across these rims and couldnt say no. The spacers are hubcentric, but I do have the rubber hub that came with the wheels that I would use even if I did not have spacers. ill be taking them off again today for another evaluation because they are being ridiculous.
    Registered User Two Rings john@fifteen52's Avatar
    May 02 2008
    B7 A4, Mk3.5 Cabrio, Mk5 Jetta
    White Plains, MD
    Spacers shouldn't make any difference in noise at all. If you bought the wheels/tires used and they have 60% tread left, it is most likely tire noise. Some tires make a lot of noise when the tread wears down. The car they came off of also could have had a bad alignment. Inspect the tires for uneven wear or cupping. You can also try to swap wheels from front to back (or side to side if non-directional) and see if the noise changes.
    I had a set of BBS CH with Yokohama Parada tires that started making a howling noise after 5k miles. It was so bad I thought I had 4 bad wheel bearings. Swapping to stock wheels eliminated all noise. Tire Rack and Yokohama worked me out a deal on the (then new) Parada Spec 2 which was supposed to have reduced noise and I never had the same problem.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Nov 16 2007
    thanks i filtered through there but didnt really find what i was looking for...i guess trial and error will have to be done until i figure this out
    Nov 15 2007
    you should take out the wheel and see if its rubbing against anything. sometimes it might rub against the shock if you have aftermarket suspension.
