Results 1 to 4 of 4
    Jul 26 2008
    St.Paul
    3.0...how do you remove the alternator?
    I'm trying to get to the alternator but it looks buried on the 3.0. It's not on top like the 1.8's have it. How do you get to it? Looks like there isn't even enough space to work with?
    Jul 26 2008
    St.Paul
    Re: 3.0...how do you remove the alternator?
    you guys are telling me nobody has had to change their alternator?
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    I have changed the alternator on a Passat 2.8 which is probably similar (it's mounted on the bottom left side when you're looking at the motor from the front of the car). I had to remove the bumper and front rack (a/c condenser, radiator, etc). I was no simple job but certainly not the most complicated thing I've ever done. If you feel comfortable removing the front end of your car, its easy but time consuming... probably a five hour job. The most tedious part is getting the damn alternator out of its mounting position, as there was very little room and I had to wiggle it just right to get the clearance.
    A plus to the change is you get to flush your coolant. The downside is that you'll probably get covered in coolant when you drain it.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Jul 26 2008
    St.Paul
    That's not good news. I'm going to see if working from below is an option.
