Originally Posted by
diagnosticator
1. Yes, that is correct.
2. Yes.
3. D1 and equivalent D2 systems use the 4 pin MQS cable connectors standard.
Thank you once again.
By asking what may be perhaps redundant questions, I've gotten a better understanding of these systems and how much similar and dissimilar they are.
It's also broadened my knowledge of certain terms and expressions which facilitated a better search process.
To those ends, I was able to find a D1/D2 adapter.
This adapter is the exact same size, shape and dimensions as the D1S and D3S igniter and has the 4 pin D2S MQS plug and uses a D2S bulb.
I've found a real 50W D2S bulb (Fatboy) made by Philips years ago and now discontinued but still available.
I've found a real 50W D2S ballast that when powering that 50W Philips bulb produces a minimum 5300 lumen at ~ 3900k.
The oem 35W D3S Philips bulb/igniter with oem 35W D3S ballast can produce between 2800 to 3200 lumen at 4200k depending on the bulb's age/hours.
I've also found that same D1/D2 bulb adapter in a 70W version that uses a D2S bulb.
There's also a corresponding true 70W D2S ballast.
Those two combined will power that same 50W Philips bulb to produce ~ 8000 lumens of light.
The caveat to all of this is to achieve much better light output in terms of lumens.
The D1/D2 adapter being the same shape as the D1S/D3S igniter allows this set-up to lock into place by the oem igniter clip into the light housing.
The plastic base of the D2S bulb has to be slightly notched to resemble the D3S base for those certain bulb alignment notches in the projectors base and it will snap right into place.
For the most part, the external visual looks of this set-up looks 100% oem and will fit 100% oem, including the mounting of the bulb, igniter and ballast.
I found all of this info on the HIDPlanet site.
