Results 1 to 16 of 16
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    *URGENT* Where is the crankcase breather?
    Well I am almost done getting rid of all those vacuum lines and check valves and whatnot and am curious to know where is teh crankcase breather?
    I am assuming it is the pretty big hole of you look down between the 3rd and 4th intake runners, correct?
    Anyways, the second I touched that hose (literally just touched it) it completely fell apart.
    Damnit.
    -Sami-
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: *URGENT* Where is the crankcase breather?
    if im not mistaken... on the valve cover by the firewall...
    mine was cracked, replaced under recall
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Jun 08 2008
    Calgary AB Canada
    Correct, under the intake.
    You have to take the intake off to get to it.
    Feb 19 2007
    Charleston, SC
    Martini, thats part of the crankcase breather system....
    onceover, thanks for the pic. I was able to get to it with the inatke manifold stil one, but like I said mine is damn broken. I just ordered one from mjmautohaus.com but it probably wont getr here till the end of the week, and I have to go to school monday!!
    Quick question, I believe that when I took the breather out, parts of plastic (from whats missing looks like big pieces too) fell into the breather hole...can this be a problem? I figure that if the plastic pieces fall into the oil pan, than the pickup screen will filter them out, so they dont get into the oil pump......what do you think?
    -Sami-
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    There are 2 one under the intake (the hose that broke) and the one on the back of the VC.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 19 2007
    Charleston, SC
    What do you guys recommend I can do to temporarily "gerry-rig" up the crankcase breather (the one underneath the intake mani)?
    Can I just stick a 1" tube in there until the part that broke gets shipped to me?
    -Sami-
    Feb 17 2005
    Sarasota, FL
    Hmm like this?
    Make sure you take the filter housing off before you start the car and remove anything that fell down inside, because I promise you it did!!!
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by A4ringedONE8T View Post
    Hmm like this?
    Mine looks just like that..... Funny thing, its seems as though that gold looking piece, seems to be "stuck" in there, plus I know that some pieces have fallen down in there....
    How do I take that housing off? (Please dont say remove the oil filter/cooler....because I JUST changed my oil )
    -Sami-
    Feb 19 2007
    Charleston, SC
    bump....still wondering how I can get that housing off. I have taken off 3 (of what looks like) 4 bolts. It seems as though the 4th bolt, is caught behing the oil cooler. Do I have to remove the oilfilter, then cooler?
    -Sami-
    Jan 09 2007
    Charleston SC
    I have that engine sitting in my garage, just come over and steal what ever parts you need off of it. Call me today, ill be around just cleaning the garage.
    Feb 17 2005
    Sarasota, FL
    Remove the oil filter (you dont have to drain your oil, just make sure you have a small amount to add after your done), Remove the large nut (I think its 22 or 24mm), unhook the coolant line at the hardpipe that feeds the oil cooler, slide the oil cooler off ( you will lose a bit of coolant but you can just top it off with water afterwards). This should allow you access to all 4 either 10mm bolts or 5mm allen. Be careful pulling it off, it will be stuck to the block. The gasket is metal so if you are reusing it, be careful not to damage it pulling it off
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Shawn is correct. You don't want to fire up the car with those pieces in there. The pieces could get into the crankcase and bind with your crank bearings or rod bearings. I would also replace the gasket between the block breather assy and the block.
    A more permanent solution to your block breather lines is this:
    http://www.034motorsport.com/product...roducts_id=392
    I have one waiting to be installed. Once I get my car back I'll be re-routing all of that to a catch can system. I'm gonna need a big catch can for I might be getting a lot of positive crankcase pressures with my race fuel tune. My 93 tune should be alright.
    -Doug
    Feb 19 2007
    Charleston, SC
    Thanks Shawn, but I figured it out....hopefully I wont have ny trouble with either the metal gasket or the o-ring for the oil cooler.
    Doug, thanks for the link, too bad I didnt know about that yesterday, that would be perfect for me, but I alrwdy bought the damn $50 OEM piece.....damn.
    -Sami-
    Feb 17 2005
    Sarasota, FL
    Damn, glad I got the VW one (not because of price but it was differently sized/positioned and worked better for how I have it connected) and only 24 bucks
    Dec 03 2005
    2 pedals 1FG
    connecticut
    $50! That sucks. I have an extra one too (I think). It was on the TT engine I took apart.
    -Doug
    Feb 19 2007
    Charleston, SC
    Yea, I think I might have that place I ordered from give me a refund.
    Plus I made this temporarily (seems to be holding great, so I just might keep it or go the route that is posted in the link Doug put up.
    -Sami-
