Results 1 to 7 of 7
    Registered Member Two Rings Five1ohA4's Avatar
    Dec 21 2007
    Twin Falls, ID
    high milage plus GIAC ecu upgrade ?
    So after reading review after review after review on ecu upgrades and also exhaust systems I have decided to go with the awe exhaust and the GIAC fx03 BI program. Now my question is I my car just turned past the 100k mark a couple of days ago. I understand that the GIAC program has a stronger torque curve than other manufactures and I was wondering if this might be an issue with so many miles or should I look into possibly another manufacture that is more smooth through out the power band like revo, apr, unitronic, etc... Thanks.
    2004 A4 1.8T 6spd
    18" BBS RS II
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    Re: high milage plus GIAC ecu upgrade ?
    no problems many people well over. just make sure you did full synth big filter changes every 5K and plugs yadda. good maintenance. also worst case you might end up upgrading to a k04 or BT when the turbo dies. everything else will start falling apart about 105K :)
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Dec 21 2007
    Twin Falls, ID
    Ive been good on the upkeep of the car, oil, plugs, etc.. 105k huh? thats right around the corner for me.
    2004 A4 1.8T 6spd
    18" BBS RS II
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    I'm @ 50K and when you go to the GIAC FX03 file, weak areas will be exposed. Gotta figure that the car is running what, 8 Lbs. of boost and are now pushing 20-21Lbs.
    Hoses and coil packs will almost definitely crap out.
    I went through a coil pack and I keep blowing the hose connecting the throttle body and intercooler off at partial boost to give you an idea of how the new power will affect things.
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I did the GIAC FX at around 93k with the AWE exhuast and haven't had any issues. Prior to doing it though I did and oil change, large filter, new plugs and the Hitachi "E" coils, and my TB job to be on the safe side, and a Forge 007 DV. I had no issues with the throttle body hose blowing off. I just passed 100K and going strong.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Only problem i had after the giac was the hoses now that I replaced everything the car is very very fun to drive.... I also did a full maintenance from gear box to plugs to coil packs
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Like Dema said, weak areas/worn items will most likely be exopsed. What if any issues you may have will be left to be seen till you get it done. In addition to what was stated above, your clutch (if it's still the origional) may start to slip. I have REVO, but going from stage 1 -stage 2 my oem intercooler endtanks seperated from the extra boost. Also if you don't yet have an aftermerket DV, you might as well just get one now as the stock one most likely will fail being that old and w/ higher boost levels.
    I also have an AWE exhaust/ER TP. After having the BI file and stock exhaust, stock exhaust and TP and finally the full exhaust and TP, I have to admit that it not only helps w/ performance, but also on a longevity side of things; my turbo doesn't get nearly as hot as it did w/o the AWE. I don't have before/after EGT's, but before if I got on the car at all or even putting sustained load on it (long hill, etc); when I would pop the hood the turbo would be glowing red (from slightly glowing to "damn...that can't be good for it"). After the AWE/TP I have yet to even see it start to glow red.
