Has anyone installed AWE's DTS (themselves). I tried and ran into a little debacle. I was trying to bolt up the aluminum block and mount to the trans. and realized that the mount I was trying to secure had to be bolted to the aluminum block and the trans w/ the same bolts.
Humm! One bolt two separate sets of threads. I am not a mechanic by any means although, I do consider myself mechanical inclined and I am pretty darn good at reading and interpreting directions, after all I have successfully made it through two years of Law School. I figured if I am installing a drive train STABILIZER that it would make sense to have it secure and not loose. After all it’s called a stabilizer. How do you tighten a bolt when going through two separate and independent sets of threads???
So, long story short the bolt broke off inside the trans and the aluminum block is just dangling there. I'll have to try to drill out the bolt or get out the air saw and hack off the bolt and bag this thing.
My question is: Can I drive the car to the shop if I feel I cannot continue w/ the install WITHOUT the OEM trans brace I removed? How critical is the brace and bolts I removed?
Step 4: F'd me up big time!
http://www.awe-tuning.com/media/pdf/DTS_install.pdf
Any input is appreciated. Thanks, I know I F'd up.
