Results 1 to 19 of 19
Thread: turbos?
    Registered Member Two Rings audidub0490's Avatar
    Sep 05 2008
    04 audi a6 2.7t and 99 S10
    jacksonville nc
    turbos?
    can you fit anything other than thw k03 or ko4 in the a6? because i can pick up t3/t4 or bigger turbos pretty cheap.... anyone know?
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Re: turbos?
    Not unless you have a 3.0 and want to build the motor. I suppose you could put a GT kit on the 2.7t but don't quote me cuz I haven't heard of one, but if it works on an S4 it should work in the A6
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Sep 05 2008
    jacksonville nc
    Re: turbos?
    hmm what else besides a chip is available to help make some power? preferably cheap ways...
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: turbos?
    drive down a hill
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Sep 05 2008
    jacksonville nc
    Re: turbos?
    funny guy
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Re: turbos?
    RS6 turbo would be one (RS4 has larger wheel than K04, no?), but I understand turbos alone won't do that much without fuel changes as well. Hence, $. Daft and Endeee are the resident experts on this.
    Anybody using an S-flow intake mod? I was thinking about that as inexpensive tweak.
    wofman
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Sep 05 2008
    jacksonville nc
    Re: turbos?
    s-flo intake mod? im up to try some experiments but nothing to extensive. but yeah with air comes fuel i know that much... hmmm
    Senior Member Two Rings East2.7Six's Avatar
    Apr 18 2008
    Audi A6 2.7T
    New Jersey Shore/Philadelphia
    Re: turbos?
    if you want noticible power gains then you will need the chip and a K&N or S-flo air filter... new DVs with fresh silcone lines... so $600 is the cheapest your gonna get for such a great power gain... as for i am currently saving up for tip chip and giac chip combo.. 1100 well worth it!
    "Sometimes you gotta roll a hard six."
    Sep 05 2008
    jacksonville nc
    Re: turbos?
    whats the advantages of tip chip?
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    Re: turbos?
    I have the S-Flo, i think it feels a bit smoother with it in.
    2004 Audi A6 2.7T
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    Re: turbos?
    the S-flo look o.k.. but for almost 200bucks just for a 8-9hp gain.. that's expensive.. 22bucks per horse..
    I heard the tip chip gives it a smoother ride and shorten the log from 1 sec to .2 sec, or something close to that figure. i'm too lazy to look it up. is this chip only for older models of the 2.7t??.. cuz all i seen is for 2000 to 2002 models..
    anyways the cheapest mod for your money is i guess a chip. but 600 + labor(75). and that's about a 50hp gain.. $13.50 per horse!!!!
    Apr 01 2008
    2010 Jetta TDI
    Re: turbos?
    $22 is hardly "expensive" -- chip is obviously cheapest bang -- just think about Stage 3.
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Re: turbos?
    You can put whatever turbo/turbo's you want to on your car as long as you can find a way to bolt it up or find a spot for it. Now obviously the bigger the turbo the more lag and you get and your going to be making more power so you will have to strengthen the internals. Your best bet for the lowest price and direct bolt on would be ko4's.
    Besides a chip, do the darintake, get some downpipes and your set.
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Sep 05 2008
    jacksonville nc
    Re: turbos?
    alright... so i take it that just eliminating the stock airbox and putting a k & n cone type filter on does nothing for it?. advantages of replacing the stock DV's? and last question... how would i go about making the turbo sound more noticeable. not loud but just want it to be there
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Re: turbos?
    Quote Originally Posted by audidub0490 View Post
    You're not going to see much gains by replacing the stock airbox. Stock DV's leak, mine must have been real bad, after i replaced mine I gained a couple of PSI and it just felt a lot stronger.
    Putting a cone filter on, replacing the diverter valves, downpipes and exhaust will make the turbos more noticeable. The downpipes and exhaust being the most noticeable difference for me
    452AWHP, 475AWTQ
    B8 A4 - Stock
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Re: turbos?
    Quote Originally Posted by Killerteve View Post
    www.autospeed.us has Garrett GT28RS package.... not cheap though
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    Re: turbos?
    taking out the stock airbox wouldnt be really recommended. you will heatsoak your intake. the AWE s-flo gets installed inside of your stock airbox and i think its awesome.
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Apr 01 2008
    2010 Jetta TDI
    Re: turbos?
    Audirs -- I've been confused about conical vs S-flo. I think you hit it right, esp for "stage 2" -- keep it in stock airbox (b/c heat) seems to be the right advice. There's also the Darintake matter of extra holes I also don't really comprehend. Anyway $2 per hp added seems fair to me.
    see PM to you re your catback plans -- figured I shouldn't hijack, as I tend to do so
    wofman
    Sep 05 2008
    jacksonville nc
    Re: turbos?
    alright.. thanks guys
