Results 1 to 8 of 8
    Active Member Two Rings Merceded's Avatar
    Sep 06 2008
    Infiniti G37x
    Kearny, NJ
    Cooling Fans From HELL!!!!!
    Ok so this is my problem....
    The fans keeps kicking in once the car has been off for a few minutes and it keeps going, switching from low speed to high speed until it drains the battery, and when I use the key fob to lock/unlock the car, it seems to stop the fan for a couple of seconds, and then it starts again. And the fans turn off when I switch the key to the on position without turning the car on.
    The car is not overheating, nor it has any heating problems, the fans work normaly once the car is on. And the temperature gauge reads normal all the time, nothing erratic or out of the normal.
    I ran the Vag-Com and no codes at all
    I have a 2002 Audi A4 1.8T Quattro 5spd (8E B6) With an APR Chip and GFB BOV.
    This is what I have gotten from other sites and people what it could be, but i dont know where to start or if it even applies to my car:
    1. AC/Electrical Fan Relay #53 (Part# 141-951-253 B) that its staying open once the car is off.
    2. Air Condition Pressure Sensor faulty
    3. Thermostat Switch
    4. Thermal Fan Switch
    5. Cooling Temp Sensor
    6. Cooling Temp State/Sender
    7. Fan Control Unit/Module
    Where should I start? And where are these parts and switches located in the engine/car. Or what else can it be?
    Please HELP!!!
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Re: Cooling Fans From HELL!!!!!
    Erratic fan can be caused by the "rear coolant flange/temp sender" failing. From what I have heard and experienced, it is typically turning the fan on even when engine is cold. I've not heard of it running the fan to the point of running a battery down, but maybe I just caught mine in time. $11 part at napa and a real pain in the ass to replace, but easily accomplished in an hour. Pretty sure there is a DIY on a4mods.com replace with the upgraded Green one.
    Mine threw a code when it failed. Hope it ends up being a simple fix, good luck!
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Jan 06 2007
    Vermont
    I think I heard others with this problem say it was the fan control module that was faulty...I see you have that listed.
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Hmmm... I hate the issues where there could be 1 million possible fixes. You just made me realize that my fans never come on when I turn the car off. I don't have any codes and no issues overheating, but when i shut the car off, its off, no moving parts or noises of any kind. Wondering if I have a problem....?
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Sep 06 2008
    Infiniti G37x
    Kearny, NJ
    FIXED! The ECU storage cover was cracked and water was leaking during the rainy days, which summerged the Relays under the ecu and damaged it, I replaced the damaged ones and WhAM! all was back to normal. But I fixed and sealed the ecu cover box.
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by Merceded View Post
    that was going to be my suggestion.
    Oct 27 2006
    ct
    99 percent of the time a fan running all the time will be the coolant temp sensor.
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    I just fixed mine last night and it was a cracked ECU coverletting water in and damaging the relay. Got a new relay and cover for $80 at the dealership!!
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
