Results 1 to 13 of 13
    Veteran Member Four Rings superman_006's Avatar
    Jan 14 2007
    Porsche 996 C2
    WV
    rebuilding the 1.8t
    So, I've ready to rebuild the 1.8t, it runs fine, but I've got some oil leaks (oil pan), a few lifters ticking once the motor is warm, and 160k on the stock motor. I am going to just remove the head and the oil pan.
    So here is what all I've got in mind
    lifters
    rings
    rod bearings
    oil pump
    head bolts
    what I am wondering is about the valves....I've seen where some poeple rebuilding the AEB replace the intake valves, I am just wondering why just the intake valves? do they wear more/ diffrent?
    2015 Audi Q5 S-line 3.0T
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: rebuilding the 1.8t
    I doubt you need new valves. If the car burns oil, you can replace the valve seals and retainers. I seen good prices for all lifters at www.mjmautohaus.com. Might as well replace the rods in the motor while the pistons are out which will allow you to run more power if you replace that GT2X.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I honestly wouldn't tear down my own 1.8T without planning on replacing rods.
    Call up Bob (QEDpower) and he'll break everything down for you, and probably give you the best price on stuff. He'll probably sell you the "Rod install kit" and some goodies you choose.
    Jan 14 2007
    Porsche 996 C2
    WV
    I didnt relize the stock rods were so weak... Im running 22 psi on regular gas.... I was running 26psi when I was running high test (when it wasnt $5.00 a gallon)
    should I be looking for some H beams?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Scat or Integrated Engineering. $350 per set of 4. Well worth the investment if you're already in there. Stock pistons will be fine for most people's ambitions too.
    Jan 14 2007
    Porsche 996 C2
    WV
    Whats the wieght deffrence (stock vs aftermarket). The torque isnt all that great with the A/C on already
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    You didn't list a head gasket but I'm assuming you will be replacing that too.
    Also replacing the rods is not a bad idea since they are only a few hundred bucks and it will give you peace of mind.
    Jan 14 2007
    Porsche 996 C2
    WV
    Yeah Im replacing my head gasket, oil pan gasket, all the valve seals
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Dont forget intake manifold gasket and exhaust manifold gasket and you should put in new rod bolts if you are going to reuse your stock rods since the bolts stretch when you torque them. Probably be a good idea to throw in new valve cover gasket too while you are at it.
    And the tapping may just be your cam chain tensioner being worn out and not your lifters.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Also timing belt kit, valve cover gasket, and any other little things that shouldn't be reused.
    Definitely swap in a set of Scat rods and new rod bearings while you're in there. Rings can be optional but I did them too.
    Jim
    I Do Werk.
    Apr 22 2007
    Riverbank, Ca
    Swap in the rods because most likely you'll be running a bigger turbo sometime down the road and in that case you wont have to do it again then....
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    You want to do rods for sure...
    Jan 14 2007
    Porsche 996 C2
    WV
    Do the rear cam gears unbolt?
    I replaced My timing belt/ tensioner/ idlerpully/ water pump about 5k-6k ago
